Shifter modification and car value?
Old Oct 6, 2013 | 10:10 AM
Vettesquid's Avatar
Vettesquid
Default Shifter modification and car value?
Have a 71 4speed with 350/270 engine that is almost completely restored (and original) from a frame off effort. Last challenge is the stock shifter which is worn, rubbery and occasional pops out of 4th gear. I am debating with myself on either going with a stock rebuild or Hurst. I already know the advantages of the Hurst, but I am uncertain if it will hurt, help or do nothing with the value of the car. Any thoughts? Also, does anyone have the Hurst shifter that mimics the stock one and if so, how close to the original is it in size and looks?
Thanks for the help
Old Oct 6, 2013 | 10:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Vettesquid
...Have a 71 4speed with 350/270 engine that is almost completely restored (and original) from a frame off effort...
Why not leave it that way? It's your car and you can do what you want, but the fact that you admit to being uncertain about the Hurst seems to answer that question for you.
Old Oct 6, 2013 | 10:47 AM
tokim's Avatar
tokim
I agree with Easy Mike.
Seems you have made a great effort to restore it and keep it original.
My '71 retains the stock shifter, and it works beautifully.
Old Oct 6, 2013 | 11:06 AM
John 65's Avatar
John 65
I would install the hurst and just hold on to the original shifter for a future sale of the car. Have had both, just no comparison in my opinion. You can even dress it for a stock appearance. Good luck.
Old Oct 6, 2013 | 11:23 AM
Priya's Avatar
Priya
As long as you've got the original shifter to go with the car its trivial to put it back to original and in my opinion will have no effect on the value of the car. The Hurst shifter is way nicer than the factory piece.
Old Oct 6, 2013 | 12:12 PM
Alan 71's Avatar
Alan 71
Hi Vs,
While I generally like the look of the Hurst shifter and it's operation, it does bother me, "as the 'dreaded' purist", when I see one in an otherwise stock looking interior.
Have you considered the Hurst shifter with the stock looking lever and ball that's available for it?
A properly shimmed and adjusted stock shifter is pretty nice to look at and use.
Regards,
Alan
Old Oct 6, 2013 | 04:31 PM
Vettesquid's Avatar
Vettesquid
Thanks Alan,
I am considering the Hurst replica of the original shifter handle, but I have never seen one in the flesh.
If anyone has, please let me know how close to the original it appears
Old Oct 6, 2013 | 04:54 PM
John 65's Avatar
John 65
Its a perfect illusion. Even the reverse lockout is spring loaded.
Old Oct 6, 2013 | 05:59 PM
Vettesquid's Avatar
Vettesquid
Perfect - thanks.
Seems like the best of both worlds. Will keep original just in case I have a change of heart in the future.
Old Oct 6, 2013 | 06:02 PM
Alan 71's Avatar
Alan 71
Hi John,
Thanks for the picture!
Even the purist is happy!
Regards,
Alan
Old Oct 6, 2013 | 06:12 PM
John 65's Avatar
John 65
Hi Alan !
To Shifter modification and car value?
