Negative Cambor (camber)???
Old Oct 6, 2013 | 06:24 PM
txdoglover's Avatar
txdoglover
Default Negative Cambor (camber)???
What do you guys think? Hope pics post this time.
Old Oct 7, 2013 | 08:54 AM
txdoglover's Avatar
txdoglover
bump
Old Oct 7, 2013 | 09:32 AM
runningstart's Avatar
runningstart
How much camber do you have there?
Old Oct 7, 2013 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What's the question? If you are concerned with camber, have the car aligned.
Old Oct 7, 2013 | 08:21 PM
txdoglover's Avatar
txdoglover
I'll take another picture that shows it better and post it. I don't know how much camber there is, have gotten differing opinions on whether it looks cool, or if it is harmful. I didn't think alignment was what would fix it. I thought it was a more expensive repair than that. I will repost. Thanks
Old Oct 7, 2013 | 08:40 PM
briankeery's Avatar
briankeery
For our cars, the daily driver normal street use camber spec is 0* +/- .5*. Therefore your rear wheel should be almost vertical. Get a 4 wheel alignment done to see if components are still in spec.
Old Oct 7, 2013 | 08:41 PM
txdoglover's Avatar
txdoglover
Hope this shows it the way that I can see it. Just trying to get opinions on it. If there is camber how much is too much and is it mainly tire wear unevenly that is a problem or are there other problems associated with it? Thanks guys!
Old Oct 7, 2013 | 08:43 PM
txdoglover's Avatar
txdoglover
Thanks Brian, mine sure don't look vertical to me. I think they splay out pretty obviously, but it doesn't look like it to me in these pics I've taken. My husband thinks this above pic does show it. Thanks for any help with this.
Old Oct 7, 2013 | 08:56 PM
'75's Avatar
'75
Easy way to check it is go get a cheap level made of plastic or aluminum. Cut it the right length so it will fit flush on your wheel and check to see if it's vertical. If you have to pull the top of the level out away from the wheel to make it level, then it's negative. A 1/8" gap at the top iirc is -.5 deg.
Old Oct 7, 2013 | 09:09 PM
txdoglover's Avatar
txdoglover
'75, thanks, that makes sense.
Old Oct 7, 2013 | 09:16 PM
briankeery's Avatar
briankeery
The rear strut rods that adjust camber are moved by an elliptical washer up near the differential. If you have bushings that need replacing on the rods, a lot of guys opt for adjustable strut rods through a vendor. I recommend heim jointed rods.
Old Oct 7, 2013 | 09:45 PM
runningstart
Negative camber improves handling at the expense of tire wear, so no there are no other issues with negative camber.
Old Oct 8, 2013 | 07:04 AM
txdoglover's Avatar
txdoglover
Okay, Thanks guys!!
Old Oct 8, 2013 | 07:53 AM
Easy Mike's Avatar
Easy Mike
Have the car aligned. Home made driveway alignments can get you in the ball park close enough to drive to the alignment shop. Why guess about eyeball scale camber?
Old Oct 8, 2013 | 12:31 PM
tracdogg2's Avatar
tracdogg2
You have excessive camber. An alignment won't fix this. 1979 was the worst year for stub axle wear. Read this thread, it will explain a lot.
Mike
http://forums.corvetteforum.com/c3-t...haft-play.html
To Negative Cambor (camber)???
