which direction does oil pump spin
Old Oct 7, 2013 | 11:56 AM
Bills1974C3's Avatar
Bills1974C3
Cruising
Default which direction does oil pump spin
I'm using a drill to pump the oil in a motor that hasn't run in twenty years. I have the tool to reach oil pump which direction do I set the drill to spin and how fast?
Old Oct 7, 2013 | 12:03 PM
76Rat's Avatar
76Rat
Looking fom the top it spins clockwise.
Old Oct 7, 2013 | 12:14 PM
Bills1974C3
Cruising
I haven't the valve covers yet. just want to make sure i'm spinning it in the right direction
Old Oct 7, 2013 | 12:24 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I think you'll find that unless you're using an air drill or a very powerfully electric, your drift will run out of oomph and regulate its own speed. When it finally primes there should be a fair bit of back pressure.
I wouldn't go crazy with using a high speed drill but pretty much anything a battery operated drill can do will be fine. Once primed, I switch to the low range.
Also remember to keep the valve overs in place and just check them periodically. You'd be astounded how far the oil will shoot out of the top of the pushrods when priming. This oil spray will inevitably find something that you don't want oiled. Ask how I know.
Old Oct 7, 2013 | 02:02 PM
jnb5101's Avatar
jnb5101
if the engine is in the car, make sure the oil line to the gauge is connected! don't ask!
Old Oct 7, 2013 | 06:07 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I smoked an old non-variable speed corded 3/8" drill doing this once. I since bought a more heavy-duty variable-speed corded 1/2" that does this job nice and powerfully slow to prime those closed cavities.
Anticipate the resistance because cold engine oil flows like syrup. Good luck.
Old Oct 7, 2013 | 07:52 PM
bpassmore's Avatar
bpassmore
Use both hands on the drill, when it catches hang on.
To which direction does oil pump spin
