painting rotors help
Since very little of the rotor shows which is not the braking surface, I'm wondering whether you mean painting rotors or painting calipers.
In the same vein that many cast iron master cylinders are left bare to rust, I wanted to "dress up" the hub or visible portion of the rotor once the suspension is completely assembled and the car is on the ground.
I know that any surface rust on either of these components have no ill effect on their performance so this was nothing more than detail work for appearances sake.
I also knew with 5-spoke wheels, the hub can be more easily seen. After measuring how much bare metal is exposed below the disc pad towards the hub, I masked off both sides of the rotor where the pads clamp down. Shot with high temp black.
I also thought that the rotor vanes can sometimes be seen so I shot inside of them with a high temp clear. This was my result and though they are not correctly restored Stingray, they still keep the rust from developing and to date, clean up nicely.
YMMV.
If the OP was searching for this component as an example, then there you go. Good luck.
When I last painted a set of rotors I simply used a couple pieces of cardboard with openings cut out to go over the rotor hub.
I made sure that the cardboard was large enough to cover the actual braking surface.
Worked like a charm, didn't make for extra work to clean the braking surface, and didn't cost anything extra!
