1968 Engine Stamp Pad Question
Old Oct 12, 2013 | 07:52 AM
Jeffrey67's Avatar
Jeffrey67
Default 1968 Engine Stamp Pad Question
Hi guys, I am in the middle of rebuilding my 68 427/390. (Actually my mechanic is, I'm just watching and asking alot of dumb questions)...the stamp pad reads.."TI120IL" on the left side of the pad. The right side is blank. I had a 69 Vette a few years ago, and the right side had the suffix of the VIN #. Is my blank pad indicative of an engine replacement, or is this typical of '68's?? Thanks.
Old Oct 12, 2013 | 08:05 AM
Alan 71's Avatar
Alan 71
Hi J67,
I'd think you'd typically see the serial number derivative of the car the engine went into at St.Louis on the right side of your pad.
The IL suffix does indicate a 427/390 engine for a 68 Corvette though.
Have you checked to see if there is a vin derivative stamp on your transmission.... and does it agree with the vin of your car?
regards,
Alan
Old Oct 12, 2013 | 09:05 AM
Revi's Avatar
Revi
The engine is dated Nov. 20th, you can compare that with the cars build date.
Old Oct 12, 2013 | 09:16 AM
Jeffrey67's Avatar
Jeffrey67
The trans reads GM 3884685
The VIN reads 194378S428079
Old Oct 12, 2013 | 09:17 AM
Jeffrey67's Avatar
Jeffrey67
The build date, is August 1968, I believe.
Old Oct 12, 2013 | 09:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
IL is the correct code for the 427/390 with manual transmission. Look opposite the engine stamp and see if you have a VIN derivitive stamp. The charactors of the VIN derivitive will be smaller than the engine stamp.
Old Oct 12, 2013 | 09:20 AM
Jeffrey67's Avatar
Jeffrey67
From the C3 Registry:
Body and Drive train Specifications:
Vin# 194378S428079
Body build code M06 =August 6, 1968 Paint code 986=Silverton silver w/ Black interior
Engine block cast #3916321 cast date "E", May 1968, IL 390HP 427
Heads oval port cast #3917215
Manifolds cast #3880827 and 3880828 ( Corvette only)
Intake manifold #3937793 mid year up 390HP 427 Corvette only
Carburetor Rochester MV4 #7028209= 390HP 1968
Transmission code 180K8P = Muncie, build date July 1968 Matching vin# as car
Rear axle cast F128=June,12, 1968 Build stamp AT72468= HD Posi-traction 3.08
gears assembled July 24, 1968
Old Oct 12, 2013 | 09:40 AM
Alan 71's Avatar
Alan 71
Hi 69,
I believe the number you listed for the transmission is the casting number for the case.
Try to find the stamped information. It's on the side of the transmission's flange.
Regards,
Alan
Here's one fro a mid-January 71:
P: Muncie
1: Model Year (not calendar year)
T: December ( calendar year)
21: Day
A: Wide Range
vin sequence is below "X out".
Old Oct 12, 2013 | 10:17 AM
Jeffrey67's Avatar
Jeffrey67
I will look at that. So...if I show the car, what is the truthful answer as to why there is no VIN on the stamp pad. Is it a certainty that it was removed (indicating a non-matching block) or are there certain scenarios when a pad may not have a VIN? For example, what does this info from the C3 registry indicate?
Old Oct 12, 2013 | 10:51 AM
Mike Ward's Avatar
Mike Ward
Take whatever's in in the registry with a grain of salt. People can fill in whatever they like- it's not validated.
Post a pic of your pad if you want suggestions of what might have happened.
The engine assembly date indicates Nov 20th. Your car was built within a few days of the end of '68 production in August '68. If your engine was assembled in Nov. '68 obviously it's not the original. If it was assembled in Nov. '67 it would be unlikely for it to sit around for 10 months waiting for your car. The unexplained missing VIN stamp makes it even more unlikely.
As for what to say at car shows, tell them that your engine was Duntov's office paperweight. He loved it like a child and they had to wait for him to go on summer vacation to sneak it out for installation in a car.
Don't worry about the truth- nobody else tells it, why should you?
Old Oct 12, 2013 | 11:52 AM
Jeffrey67's Avatar
Jeffrey67
Mike, I like your attitude. Can't wait to get my freakin' car back!
Old Oct 12, 2013 | 11:57 AM
Jeffrey67's Avatar
Jeffrey67
Is erasing 1/2 the engine pad typical when a replacement engine goes in? I figured someone would erase and restamp the whole thing.
Old Oct 12, 2013 | 12:58 PM
Alan 71's Avatar
Alan 71
Hi j67,
Have you looked for the transmission stamp?
The SAME vin derivative stamp was used for the engine pad and transmission pad and they were typically done at the same time.
It's really not likely that the engine vin derivative was not stamped while the transmission was stamped.
So, is the transmission stamped?
If just part of the engine pad SURFACE has been worked on there would likely be clear signs of that.
Regards,
Alan
Old Oct 12, 2013 | 03:02 PM
BBCorv70's Avatar
BBCorv70
I've heard of an alternate stamp location, think it was near the oil filter? Was this possible for 68?
Given the engine build date came after the car assembly date, it seems unlikely the block is original. Is it possible it's a replacement engine, already built and dated but not installed by the factory?
Old Oct 12, 2013 | 04:53 PM
Jeffrey67's Avatar
Jeffrey67
Can the trans stamp be seen with the trans installed? Yesterday the trans was out. Today it's in...
Old Oct 12, 2013 | 10:17 PM
Jeff_Keryk's Avatar
Jeff_Keryk
My 68 L36 numbers are pretty dim.... Damn that machinist!
Old Oct 13, 2013 | 09:23 PM
Mike Ward's Avatar
Mike Ward
They weren't 'erased', never stamped in the first place.
To 1968 Engine Stamp Pad Question
Old Oct 16, 2013 | 01:46 AM
tooright's Avatar
tooright
Hello there, Jeffrey67 ...... Tooright.
Same issue with my '68 427/435. I purchased this car in 1975. 1979 I had the engine balanced and blueprinted in Lafayette, IN. I remember the machinist telling me if I ever needed these numbers I would have to bring them out by etching the area with acid as the milling of the block during the rebuild made the numbers very hard to read.
I have worked on cleaning the area and am able to read T1025 IR. The block cast date was I 11 7 (Sep 11 '67). Car came off the line Nov '67 ..... all good, but ..... like you .... unable to read vin assembly number. (Your block may have been milled as well)
DOES ANYONE HAVE AN IDEA IF ACID ETCHING COULD WORK? IF SO, MURATIC OR WHAT?
Old Aug 13, 2015 | 01:13 PM
gavino's Avatar
gavino
Default Possible answer
I have a 68 427,435 with a similar problem. When my friend and I were trying to identify all numbers on the car the engine number had no vin # stamped on the pad. He had a friend at NCRS and asked him what it could be. The answer we received was that it was probably a short block replacement for an engine that had blown out. He also said that there would be no or a slight deduction in judging the car. Who knows how many of those first engines wet the bed. The date on the replacement would have to be in the warranty period for the vehicle to assume that this was in fact the case.
Old Aug 13, 2015 | 03:53 PM
Alan 71's Avatar
Alan 71
Hi g,
You seem to be saying that in Flight Judging the NCRS gives a replacement block a 'mulligan'…. is that really so? ("no or a slight deduction").
Regards,
Alan
