Vacuum Nipple
Old Oct 13, 2013 | 07:18 PM
Rumbles1960's Avatar
Rumbles1960
Default Vacuum Nipple
I need one of these vacuum nipples, don't have a junk yard near by and haven't been able to find any on line. Any suggestions?
Old Oct 13, 2013 | 09:00 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
What is its purpose? Where does it go? What year car?
Old Oct 13, 2013 | 09:11 PM
Rumbles1960
It is from my 1979 vette and connects to the heater control valve under the hood but I have seen it inside the car at the vacuum actuators inside the car as well.
Old Oct 13, 2013 | 09:51 PM
jbrown8238's Avatar
jbrown8238
NE Events Coordinator
By heater control valve do you mean this part?
Old Oct 13, 2013 | 11:10 PM
TimAT's Avatar
TimAT
That style is to keep the hose on the fitting. fold the small end over, slide it on the valve and then straighten the end over the valve fitting. Might be a tough replacement to come up with. You can get a short piece of standard vacuum hose that will slip onto the fitting and then insert the line into that. Think of it as a splice connector.
Old Oct 15, 2013 | 09:47 AM
Rumbles1960
Trying to keep it original under the hood, can't believe anybody hasn't ever run up against this before.
To Vacuum Nipple
