81 transmissions
Old Oct 15, 2013 | 05:36 PM
81 vette vent's Avatar
81 vette vent
Default 81 transmissions
Did GM put turbo400s in some of the 81 vettes? I'm looking at a vette with a blower motor but the guys says it has the stock trans and rearend in it. He said it's mildly built and he has only took it to car shows for the last 15 years. I just don't know if any of the 81s were stronge enough to handle 450~500 hp. He says it has a 400 trans in it but I think he doesn't really know and I know the weak overdrive trans can not handle this type of power. I know they put stronger rearends in the ones with 4 speeds. Other than that I'm not sure.
Thanks for any info.
Old Oct 15, 2013 | 05:42 PM
540 vette's Avatar
540 vette
Crawl under it and look at the pan. That will tell you what trans is in it.
Old Oct 15, 2013 | 06:06 PM
chopperb's Avatar
chopperb
I believe the th350 was the only auto available in the vette back in 81.
Old Oct 15, 2013 | 06:22 PM
SIXFOOTER's Avatar
SIXFOOTER
TH350C is the only auto that went into the 81's, only 1 motor choice too.
Old Oct 16, 2013 | 08:24 AM
81 vette vent
I was afraid of this. Do you guys think the drive tran can handle the power? I was told the overdrive will burn out with too much power. I could disconnect the overdrive if that would help.
Old Oct 16, 2013 | 08:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 81 vette vent
...Did GM put turbo400s in some of the 81 vettes?...
No. GM did not. A PO might have made the swap.
Una4dbl55's Avatar
Una4dbl55
the TH350c does not have an overdrive
however, it does have a lock up converter
Old Oct 16, 2013 | 08:44 AM
81 vette vent
If he put a stronger converter in, would that hold up? Maybe a stall-converter. I can tell when I get there, I just wish a 400 was put in there back when it the motor was built.
It just doesn't make sence on the phone. He said 400 and then he said shifts 4 times. Could it be a 700R? And are they stronge enough?
Old Oct 16, 2013 | 08:48 AM
qwank's Avatar
qwank
if it shifts 4 times it's a 5 speed
Old Oct 16, 2013 | 10:30 AM
7T1vette's Avatar
7T1vette
He doesn't know what he has. You don't know what he has. If it were me, I would pass on an "unknown quantity"...
To 81 transmissions
