f41 suspension question
Old Oct 23, 2013 | 03:18 PM
9492's Avatar
9492
Default f41 suspension question
Can you tell a difference between the standard front suspension spring and the F41 front suspension spring visually? There is someone local selling what they claim to be original F41 front springs. They look just like the standard ones I've already got. Thanks
Old Oct 23, 2013 | 03:43 PM
roadblock69's Avatar
roadblock69
The F-41 springs are shorter than the standard spring, have fewer coils and a little thicker material. I hope that this helps.
Old Oct 23, 2013 | 03:49 PM
MelWff's Avatar
MelWff
As stated above the F41 has 7 coils and thicker wire.
Old Oct 24, 2013 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If the original spring code tags are still on them, you read the codes.
Old Oct 24, 2013 | 10:55 AM
v2racing's Avatar
v2racing
If they are originals, they will not be a 550 lb spring anymore. All steel springs will lose their tension over time and use. The good news is they are not very expensive to replace.
To f41 suspension question
