Headlamp Assemble - Loose
Old Nov 8, 2013 | 02:12 AM
Ttopp's Avatar
Ttopp
5th Gear
Default Headlamp Assemble - Loose
Hello all,
I noted that the headlamps near the middle of the car have become very loose. The headlamps themselves aren't connected to any clips, and they are simply holding on to the chrome outer ring.
I try to press the ring inward, securing it in however it seems that with Maltese roads, they are bound to 'pop out' again.
How can I tackle this problem?
Thanks,
From sunny Malta
Old Nov 8, 2013 | 06:01 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Hi ttop you have to take off your head light front cover and then tighten the three screws on the chrome bezel . You cant see the screws till the front is removed .Hope this helps .
Old Nov 8, 2013 | 09:01 AM
lvmyvt76's Avatar
lvmyvt76
take it easy when tightening these screws, they will strip-out the metal they screw to.
Old Nov 18, 2013 | 04:55 AM
Ttopp's Avatar
Ttopp
5th Gear
Thanks everyone!
To Headlamp Assemble - Loose
