Tach questions
Old Nov 15, 2013 | 10:52 AM
GreenDream's Avatar
GreenDream
Default Tach questions
Bought my 74 L-82 a couple months ago. The tach cable is hanging freely in the engine bay and the connection on the distributer was covered with grime, so obviously had not been connected in a long time. I have verified the cable and gauge are good with a drill in reverse and carried about 700 rpm. I can assume two different scenarios. 1. the gear set in the distributer is shot. 2. someone had it apart and just chose not to hook it back up. I can see that as a viable option as there is no way in hell there is enough room to connect it due to the connection directly facing the firewall and only having a couple inches of clearance. So my question is, do I rotate the distributer enough to connect it and force it back to verify whether it actually works, or buy the 90 degree adapter. And if still not working, then is it wise to upgrade to the needle bearing gear sets? And what is the difference in the stainless or bronze sets? I assume that I don't have to remove the distributer to install this gear set, correct? And lastly, what is the "button" that shows in the catalogs?
Thanks for your help.
Old Nov 15, 2013 | 11:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you correctly index the distributor, no adapters of any type are required for the tach cable.
Before going to all the trouble, you can reasonably assume the PO disconnected the tach cable because the crosshaft and mainshaft gears in the distributor are probably stripped.
Do you have the assembly instruction manual (AIM)? The AIM shows the correct orientation for the distributor based on the stake marks on the stock intake manifold and housing of the distributor.
You do not need needle bearings. You may or may not need the button. Some model years use the button, other years do not.
Old Nov 15, 2013 | 11:35 AM
TimAT's Avatar
TimAT
Email Lars for his distributor install papers. IT sounds like the last person that had it out didn't install it so the cable would reach. If you can get to the cable connection on the distributor as it is now, use a small screwdriver and see if you can turn the driven gear, or start the engine and see if the driven gear is turning.
If it needs help, there are several options, but pretty much all of them are a distributor rebuild with a new mainshaft and driven gear.
Old Nov 15, 2013 | 11:43 AM
Mike Ward's Avatar
Mike Ward
The distributor is not correctly oriented. Bubba has visited your car. If the housing is correctly positioned as per GM design, no 90* adapters are required.
I'll bet that the gears have failed and Bubba made a half-*ss attempt to fix it. Replacement of the side gear and main shaft is required.
Old Nov 15, 2013 | 11:52 AM
GreenDream's Avatar
GreenDream
I do have the AIM and will check out the orientation. Thanks..
Old Nov 15, 2013 | 12:07 PM
MelWff's Avatar
MelWff
read this link and the section on the C3
http://www.corvette-restoration.com/...stallation.pdf
Old Nov 15, 2013 | 12:11 PM
Mike Ward's Avatar
Mike Ward
Not sure if the '74 AIM has the updated positioning or not. There is a GM bulletin revising the housing orientation to reduce the stress on the cable. The vacuum canister nipple and hose should be behind the upright for the ignition shielding and not in front as per previous design.
Old Nov 15, 2013 | 01:47 PM
GreenDream's Avatar
GreenDream
Good ole Lars comes through again... Could be that Bubba did not get his hands on this and that it is original factory orientation. The GM Service Bulletin allows for reorientation to straighten out the tach drive cable and promote longer cable life. I suspect a PO bought a new cable and could not get it hooked back up to the distributor. I will find out this weekend.
Thanks for your replies..
Old Nov 15, 2013 | 04:03 PM
Mike Ward's Avatar
Mike Ward
Even original factory config. works OKish. Mine operated like that for 20+ years before I bought it.
Old Nov 15, 2013 | 09:27 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I was just wondering (since my project is in a similar situation) if it would help to disassemble the distributor/clean out the old grease/replace worn parts/add new grease/reassemble/drive car for 20 more years ?
Old Nov 15, 2013 | 09:36 PM
Mike Ward's Avatar
Mike Ward
Yes.
Old Nov 16, 2013 | 02:06 AM
doorgunner's Avatar
doorgunner
Thanks M.W.
To Tach questions
