A/C delete
Old Nov 28, 2013 | 06:16 PM
diehrd's Avatar
diehrd
Default A/C delete
Has anyone done the A/C delete and used the AGM cover ?
How difficult would you say the project was ?
Thats a link to the cover
http://www.acdelete.com/pages/68-82_Y-Body.htm
Old Nov 28, 2013 | 07:54 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This rookie is guessing "done in a day".....not difficult---just time-consuming.
Old Nov 28, 2013 | 08:04 PM
diehrd's Avatar
diehrd
Ya I wonder if I gotta pull the dash or can I pull it all from under the hood . .
Old Nov 28, 2013 | 08:09 PM
jesse10886's Avatar
jesse10886
I have yet to buy the cover but I did delete a/c b/c ALL of.it was junk anyway. All my lines compressor heater core blower motor ect all fried. I will say this it took me about four hours but.it sucked mine pissed me off so I took a mini sledge and a large chisel and beat the firewall housing to pieces to get it out. If it comes apart like it should not a bad project but if your bolts are broken seized rusted or won't come apart then just keep your patients
Old Nov 28, 2013 | 08:13 PM
jesse10886's Avatar
jesse10886
Under the hood I didnt have to get into the dash to get any of my parts out
Old Nov 28, 2013 | 08:16 PM
diehrd's Avatar
diehrd
Cool no hammers for me lol and little if any rust .. Thanks !!
Old Nov 28, 2013 | 08:29 PM
jesse10886's Avatar
jesse10886
Yeah I one of the few times I lost my head on my car lol thank god I didn't do any damge to anything other than the fire wall a/c cover I was removing any way
you will very much enjoy the extra room under the hood it looks great
Old Nov 28, 2013 | 09:22 PM
diehrd's Avatar
diehrd
Ya I am installing stepped headers , big tubes 2" .. And I just did EZ EFI . I was thinking the room would clean it all up nice and possibly I can run the cold air intake over to the side inlet below that giant A/C contraption once it is gone.. I run tops off no need for a/c even on a hot day.
Old Nov 28, 2013 | 10:08 PM
John 65's Avatar
John 65
When I removed my 77 ac system, I put in a used non air heater box from an earlier year car and then fiber-glassed the rest of the opening in. Cheap, clean and it looks like it's always been there. Put a valve in the hose to keep the heat out during summer also.
Old Nov 29, 2013 | 01:45 PM
chadronvette's Avatar
chadronvette
Veteran: Coast Guard
The PIA for me was locating the resistor block. You also have to salvage a couple parts from the old "suit case" like the steel ring that holds in the blower motor. It was not a real "quick" job for me. All was done under the hood though, you do not need to remove the dash.
Old Nov 29, 2013 | 02:06 PM
BKbroiler's Avatar
BKbroiler
Here's a little incentive for you. Look at all that wide open space. I used the ACdelete cover. I eliminated the heater hoses too.
Old Nov 29, 2013 | 02:31 PM
orourke's Avatar
orourke
Installing my AC Delete was straight forward install for me. It really cleaned up the engine compartment. I'm glad to be rid of the eyesore, it never worked from the day I bought the car. My issue is, how to run the wiring. Hopefully someone will explain how they made their A/C harness work on the A/C Delete.
To A/C delete
