How many???
Old Nov 29, 2013 | 10:08 PM
MCVDiesel's Avatar
MCVDiesel
Default How many???
...1976 L48 Coupes were built with M21 4speed trannys?
Diesel
Old Nov 29, 2013 | 11:27 PM
Vet76te's Avatar
Vet76te
I think the M21 transmission was ONLY availabe with the L-82 engine option. It's my understanding that all L-48 base engine cars had the base M20 transmission.
Old Nov 29, 2013 | 11:49 PM
MCVDiesel's Avatar
MCVDiesel
Hmmm, my 76 L48 has a 76 L82 motor that the PO installed. He told me it has the close ratio gearbox which I thought was the M21. I wonder if he's mistaken or if he swapped out the trannies too. I'm going to try to make contact withhim to verify. How can I identify the otherwise? And how many 76 L48s were built with 4speeds of any type?
Old Nov 30, 2013 | 10:46 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Diesel
None. M21 available only with L82
They were all Warner 4 speeds
7845 - M20 optioned
2088 - M21 optioned for L82 production only
Old Nov 30, 2013 | 10:49 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Originally Posted by Hammerhead Fred
None. M21 = Muncie All 76 came with Warner 4 sp.
I believe the RPO for the close ratio 4 speed Borg Warner was M21.
Roughly 2100 came with a close ratio 4-speed.
Old Nov 30, 2013 | 02:10 PM
Vet76te's Avatar
Vet76te
I have re-checked all my reference points,.. And it's correct,... Only L-82's had the option of the M21 close ratio transmission.
Old Nov 30, 2013 | 03:01 PM
BKarol's Avatar
BKarol
Check the partial vin on the transmission to see if it matches the partial vin on the engine stamp pad. My vin is stamped near the Warner info on the drivers side. Another spot is on top:
http://www.pontiacpower.org/BW.htm
This will show that he also switched the trans that went with the block. Not however that it is a M21. Could be a L82 with a M20.
The suffix on the engine stamp pad will also tell you what engine you have and when it was built.
Old Nov 30, 2013 | 04:52 PM
MCVDiesel's Avatar
MCVDiesel
Awesome info! Thanks guys.
Are there any stampings or plates that identify how the car was optioned?
How would one access the build info?
Diesel
Old Nov 30, 2013 | 07:22 PM
Mike Ward's Avatar
Mike Ward
GM kept no records of option combinations.
Diesel
The VIN tag will identify which engine option the car had. The trim tag will identify paint and interior colours and style. If you're lucky there will be a tank sticker on top of the gas tank that will list the options.
It's probably not worth the bother of going after the tank sticker- just look at the car to see what it has/does not have.
To How many???
