I just stripped my 80. I used Capt. Lees. I also had tons of paint on it. It took about 3 gallons to get it done. But I got it all off. I roughed up the paint with 40 grit first and then applied the stripper.
You can't go "too far". Paint stripper will not dissolve fiberglass. The way to work with it is to apply it thick, don't brush it around, just slab it on there. It will work much better in warmer temps. Get the garage as warm as you can. You can cover it with plastic sheets to let it work without evaporating.
The paint stripper will not get rid of the factory lacquer primer. You will have to remove that the slow way. On mine we used scotchbrite and lacquer thinner.
Be sure to neutralize the chem strip with plenty of clean water. Water + dawn + scrub with scotchrite. Then switch to clean water and scrub again. Finally hose it off.
i agree with zwede. you cant go too far. i also stripped mine with captain lee's and it took mine down to.the primer. i then removed the primer by hand with. 220 wet sandpaper. then a thorough rinsing with clean water. the car sat for a month after that before going to the painter. 7 years later, still no problems.
Not mandatory, you might get lucky. But the primer is 40 years old and lacquer and it has just absorbed chem strip. There's a good chance your new paint will have issues in the future if the old primer isn't removed.
To save time and stripper, you may want to try removing that blue topcoat with razor blades. Then finish the rest with the Capt lee's. This is what I did on my current car. Once you get a feel for the blade, it moves along very quickly and by the end of the 1st panel you will be a pro. Good luck.
I had two layers of paint to get off myself I used a mild stripper,a great many razor blades and sandpaper.Yes take the old primer off the car start fresh.I used an epoxy based primer.The old primer will not be compatable with the new paints.Wash the car a few time using Dawn soap it cuts grease and will clean the stripper off the car.You may also at this stage decide to clean out the body seams and refill with glass and West System Epoxy.Remember this takes time to do it right ,don't get in a race,if you get pissed with the car remember rule one,get a beer from the fridge.If anger continues go back to rule one.Just keep in mind your having fun.
Thanks for the info so far, how thick is primer? Also, can anyone confirm fiberglass is the light gray?
The idea about the plastic on top, will need to try that... stuff evaporates quickly.
On my 69 the fiberglass ranges from light gray to dark gray.I found doing small areas at a time no more than 1-2 square feet at a time with stripper worked best.Just a note if someone tells you that you have gone too far if you hit fiberglass the early vettes did not have gelcoat.The primer in not very thick and can be sanded off easy.I found the paint to be the big pain.On my 69 the primer was the red orange colour the sandable primer on top was a light gray.From your picture you may have a little more sanding to reach the primer.
