Tapping power off the alternator?
Old Dec 10, 2013 | 01:57 AM
alconk's Avatar
alconk
Default Tapping power off the alternator?
Is there a way that you can tap power off the alternator and make it look nice? I need to run a couple of relays but like the looks of originality with the rubber boot covering the positive lead.
Old Dec 10, 2013 | 09:57 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Sure. Just run the new wire along the existing wire, push it thru the boot then install the ring terminal. Tape the wire along the wire harness and it will hardly be noticeable.
Old Dec 10, 2013 | 11:29 AM
RDCRIS's Avatar
RDCRIS
I have a junction for power on the drivers inner fender. I would think your car would have the same?
Old Dec 10, 2013 | 11:39 AM
7T1vette's Avatar
7T1vette
That is a better place to draw power than at the alternator. But, depending on 'how much' additional current you are drawing, you may need to add wiring capacity to the wire from the alt to the battery and/or to the main line where most current is being fed to that relay. If you are not drawing more than about 20 amps (additional), don't worry about needing to upgrade the wiring. If you draw more than that, you run the risk of melting one (or more) fusible-links in the wiring system.
Old Dec 10, 2013 | 01:52 PM
C3 Stroker's Avatar
C3 Stroker
That's what I used.....this junction is at the horn relay.
Old Dec 10, 2013 | 05:12 PM
gkz's Avatar
gkz
My '75 doesn't have this junction; the horn relay is on the dash harness.
What are the relays going to power?
Old Dec 11, 2013 | 12:19 AM
alconk's Avatar
alconk
Just the headlights and going to install HID so I'll need a relay for those too.
Old Dec 11, 2013 | 04:01 PM
gkz's Avatar
gkz
I had the same issue in addition to the fans. Ended up bussing (from alternator power) 4 cktbkrs together for lo beam, hi beam, fan1, fan2.
I used this: http://www.allbatterysalesandservice...cfm/2,946.html
Old Dec 11, 2013 | 05:33 PM
alconk's Avatar
alconk
Oh ok,might look for something a little different or just install a longer positive stud off the alternator.
To Tapping power off the alternator?
