High Compression Starters
Old Dec 17, 2013 | 05:32 PM
Den54's Avatar
Den54
6th Gear
Default High Compression Starters
Hi,
Just wanted some opinions on the best brand our place for a new starter.
I have a 1978 with a 383 stroker, headers and side pipes. It's hard to crank at times when I've been driving it. I've been told that I have a cheap Autozone type starter in there and it acts as a heat sink being located directly above the pipes.
Any suggestions would be appreciated.
Den
Old Dec 17, 2013 | 06:05 PM
zwede's Avatar
zwede
Late model PMGR starter. Don't know if you have the in-line or staggered starter bolts. I have the staggered and used a starter from a '95 Chevy pickup with a 454. Cranks much, much better than the '71 starter and weighs less than half.
Old Dec 18, 2013 | 09:26 AM
Den54's Avatar
Den54
6th Gear
I appreciate the suggestion. It being made in China does give me pause.
Will do some more research on it.
Old Dec 18, 2013 | 09:48 AM
Street Rat's Avatar
Street Rat
Powermaster makes a complete line of ministarters for higher compression engines. I got mine at Summit Racing. It fixed all of my starting problems.
Old Dec 18, 2013 | 09:58 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
I installed a Powermaster in my 77. I to solved my cranking problems. No heat soak, faster cranking and lightweight. Bought mine at Summit also.
Old Dec 18, 2013 | 10:13 AM
Den54's Avatar
Den54
6th Gear
Pricey but worth it I'm sure.
http://www.summitracing.com/parts/pw...te?prefilter=1
I wonder how they compare with Jegs?
Old Dec 18, 2013 | 10:31 AM
zwede's Avatar
zwede
No, I'm talking about the original GM starters for late models. It's not aftermarket.
Old Dec 18, 2013 | 11:27 AM
Ironcross's Avatar
Ironcross
a stock
this is a smart move, however a heavy duty stock starter will handle most everything and should be available at any parts house.....A bad ground will cause any starter to turn slow....many here think 'heat soak' and 99% are wrong in such a diagnosis.....EVERY THING gets hot under the hood....A strong battery, good battery cables, and a HD stock starter is all that's really needed for any compression run on the street including 12-13 compression
I also know that most of the members here believe in high dollar modified 4 and 6 cylinder imports.....not necessary as it might be as simple as a bad negative ground.......which is more often than not
but whatever, its your money....
Old Dec 18, 2013 | 11:56 AM
Den54's Avatar
Den54
6th Gear
Originally Posted by Ironcross
a stock
Most diffidently going to investigate that first. Thanks.
Old Dec 18, 2013 | 03:06 PM
BigAl5611's Avatar
BigAl5611
a stock
The mini starters are only better if you have a space issue like running large tube headers etc.
Old Dec 18, 2013 | 03:54 PM
chvet73's Avatar
chvet73
I have had my Powermaster for more than 10 years and it has been trouble free.
Old Dec 19, 2013 | 11:01 AM
joewill's Avatar
joewill
I have had hot start/slow cranking problems about every 3-4 years.. then I know it is time for a brand new battery.. get you the biggest/baddest highest cold cranking amp battery you can find.. that will solve your problem.. and of course have the best ground.
Old Dec 20, 2013 | 01:25 PM
donyue's Avatar
donyue
Hi,
Den
I replaced my stock starter when it failed. I have a Powermaster now.
I thought it made sense since I was going to replace the engine with a higher compression SBC with headers.
It has been working well with good starting power and no heat soak issues. Plus it is at least 20 pounds lighter.
Yes, it costs more but there have been no issues with fitment or performance up until now. JMHO.
Old Dec 21, 2013 | 07:45 AM
Sids04's Avatar
Sids04
a stock
Spot on.. I re did the battery terminal ends and fixed some other assorted grounding issues on my 73 and it cranks over awesome ! It used to crank over slowly after it was hot . I always attributed it to heat soak from the headers or timing.. The stock rebuilt starter is a hell of a lot cheaper than any of the high torque replacements..
Old Dec 22, 2013 | 04:47 PM
68/70Vette's Avatar
68/70Vette
General Motors Performance Parts Catalog sells GM mini-starters. They a mini-starter for small blocks and BB's with normal compression ratios. They also sell a mini-starter for 502 and 546 (?) Big Blocks. I have the "normal" ministarter on the ZZ4 and the higher performance ministarter on my 70.
I've lost track of the part numbers, they're in the catalog however. The ministarters are small in name only. They're very powerful, and being much smaller are easier to install.
To High Compression Starters
