Half Shaft protective finish
Old Dec 18, 2013 | 08:43 PM
69red's Avatar
69red
Default Half Shaft protective finish
What should I used to protect my new half shafts from rusting?I don't want to paint them and was thinking of spraying them with clear coat.
Old Dec 18, 2013 | 08:54 PM
LT-1 kid's Avatar
LT-1 kid
best protection would be paint or powder coat imo
Old Dec 18, 2013 | 09:07 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
POR 15 comes in clear.
Old Dec 18, 2013 | 09:18 PM
wheatpj's Avatar
wheatpj
I got a new set of half shafts from Corvette Central and spayed then with around six coats a Eastwood'd Diamond Clear. That was two years ago and they still look new. The car gets drive weekends,...
Old Dec 18, 2013 | 10:37 PM
1974ta's Avatar
1974ta
Default rust protection
Maybe try Rust Prevention Magic or RPM for short.
I have had good luck with it on my 70 Restoration project. However, if it is a daily driver it will likely need reapplication.
I know a lot of the NCRS guys use Cosmoline. It will require re-application. Intervals will vary depending on usage of the vette.
The problem with clear is it will eventually yellow and likely chip.
Somes guys use cast blast gray paint as well.
Bill
Old Dec 18, 2013 | 10:51 PM
hotrodnick's Avatar
hotrodnick
I used rustoleum nickel spray but mine were already rusted.
Old Dec 18, 2013 | 10:59 PM
70LQ4's Avatar
70LQ4
While I hate POR15, I think it's one of the worst products on the market, they make a product called Glisten PC. It is a cristal clear 2 part finish that absolutley will not yellow , and unlike POR15 it sticks to any clean surface. I use it to coat polished Aluminium , great stuff. Tough and durable even on Valve covers and other polished Engine parts.
Old Dec 18, 2013 | 11:25 PM
7T1vette's Avatar
7T1vette
Either seal them with several coats of good quality clear coat (if you leave them bare metal), or clean them well then shoot self-etching primer on the bare metal and follow with a few coats of good quality paint (semi-gloss black; aluminum colored engine enamel; etc.).
To Half Shaft protective finish
