Non Power Brakes
Old Dec 21, 2013 | 07:51 AM
Too Slow '90's Avatar
Too Slow '90
Default Non Power Brakes
Is the only difference between power and non power the booster?
Old Dec 21, 2013 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No. Power and standard brake master cylinders are also different. There is also specific hardware used in the power brake set up not needed for standard brakes.
Old Dec 21, 2013 | 09:05 AM
Lupigiato's Avatar
Lupigiato
Easy Mike, I will be converting my 68 to PS over this winter, and looking at the PS Conversion Kits that vendors offer, the list of parts does not include a different master cylinder or a booster. I know there are STD and power versions sold individually, so I'm wondering if I need to buy a new cylinder and a booster? As a point of reference, click on this link and at the bottom select kit components. I know some folks refer to this setup as a "slave",
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
Old Dec 21, 2013 | 11:34 AM
Brcmpbl's Avatar
Brcmpbl
The thread is about brakes, not steering. Mike is saying the master cylinder etc is different for power brakes than for manual brakes. This is in no way related to power steering of course. You won't obviously need a brake master cylinder and booster to make you power steering conversion operational.
Old Dec 21, 2013 | 02:33 PM
gbvette62's Avatar
gbvette62
The factory used a different master cylinder, for power and non power brake cars. The difference I believe was the size of the MC's piston bore.
I have been "told" that you can safely, use the non power MC, when converting to power brakes. Personally, I think if your going to the trouble of upgrading to power, you might as well replace the master cylinder, while you have everything apart. A new generic master cylinder runs about $100, and the repro Delco's go for about $150.
The attaching points on the firewall, are different for the booster, than they are for the master cylinder. To mount the booster, you need to add new holes, which can be "tricky" with the dash installed.
You'll also need new brake lines, from the MC to the brass distribution block.
Old Dec 21, 2013 | 04:21 PM
Lupigiato's Avatar
Lupigiato
well that's just a huge embarrassment on my part!!! I know the difference between the two systems, but can only say in my defense that I must've had a stroke when I read and wrote my post. Holy mackerel!!! I digress and will find somewhere to hide.
Old Dec 22, 2013 | 04:08 AM
7T1vette's Avatar
7T1vette
Nah. Just start a new thread on P/S.
Old Dec 22, 2013 | 06:28 AM
Too Slow '90
Thanks for the detail. I may be pulling the dash anyway but then again I may look at a different system.
Old Dec 22, 2013 | 08:38 AM
Easy Mike's Avatar
Easy Mike
well that's just a huge embarrassment on my part!...
You meant well, Lupi. Merry Christmas.
Old Dec 22, 2013 | 10:25 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
well that's just a huge embarrassment on my part!!! I know the difference between the two systems, but can only say in my defense that I must've had a stroke.....
Thanks Mr. L.......
not only did this rookie learn how to convert to P/B.....
but also learned how to apologize with style!
Old Dec 22, 2013 | 12:41 PM
noonie's Avatar
noonie
Manual masters are 1" dia bore and power are 1-1/8" bore, mounting holes/pattern the same.
Depending on which way you are going, you may be able to reuse the lines.
New masters are around 50 bucks at most parts stores.
Old Dec 22, 2013 | 01:01 PM
Too Slow '90
Originally Posted by lakebumm
Are you installing on a C2 , your avatar, or C3?
BILL
Bill,
It's for a '68 I just purchased.
Roy
Old Dec 22, 2013 | 03:26 PM
Lupigiato's Avatar
Lupigiato
Originally Posted by doorgunner
Thanks Mr. L.......
LOL!
Old Dec 22, 2013 | 03:28 PM
Lupigiato's Avatar
Lupigiato
Thanks for the pass Easy.
Old Dec 22, 2013 | 03:37 PM
68/70Vette's Avatar
68/70Vette
There's a modification required to the firewall also to mount up the PB master cylinder.
For my 70 I bought Stainless Steel Brake Corporations aluminum MC. Little pricey.
I converted my 70 to a Hydroboost and used the SSBC MC. Also I replaced my brake and clutch parts on the passenger's side of the firewall....a difficult job made much easier by removing the steering column. Working under the dash is just sooooo muuucccchhh fun.
Old Dec 22, 2013 | 08:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I would strongly advise having an AIM on hand for converting either to or from manual brakes. BTW, another item to bear in mind is the pushrod clevis hooks up to a different hole in the pedal arm for the linkage.
Old Dec 22, 2013 | 09:50 PM
loup68's Avatar
loup68
Army
Isn't the push rod a different length between standard and power brakes? Lou.
To Non Power Brakes
Old Dec 23, 2013 | 10:11 AM
mariobro's Avatar
mariobro
This is the first thing I did when I bought my 72 earlier this year.
parts bought.
-New Master cylinder with booster
-New brake light switch arm
The push rod on the brake pedal gets relocated up higher on the pedal arm and the new brake light switch bolts in the lower hole where the push rod was connected to.
Had the dash out as getting to the top hole to mount the brake booster is a pain. I did have to drill the new mounting holes for the brake booster.
I used all the existing lines that were ran to the manual master cylinder.
Old Dec 23, 2013 | 08:24 PM
TheSkunkWorks
Yes. And, before you ask how long is the manual one, I'm afraid I didn't think to measure back when...
Old Dec 23, 2013 | 08:32 PM
edk136's Avatar
edk136
Here's a push rod for manual brakes
