Replace firewall?
Old Dec 25, 2013 | 12:19 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Default Replace firewall?
Old Dec 25, 2013 | 12:21 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
This was not well done...should I replace firewall or try to repair?
Old Dec 25, 2013 | 02:57 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I think we need a bit more information. How was the repair done? Is it leaking? What are your concerns?
Old Dec 25, 2013 | 03:56 PM
jnb5101's Avatar
jnb5101
that looks like it may have been caused by a fire. if the damage is confined to the trans area it can be repaired by removing as much of the damaged glass as you can without perforating through, repairing it, and then doing the same from the bottom side. i had to do this to the area around the heater, and it worked out well. not a difficult job, just a pia.
Old Dec 25, 2013 | 09:26 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Cloth was used...not very smooth.
Not sure if it will take much from brake and accel use.
Old Dec 25, 2013 | 09:28 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Wiper tray looks even worse and has soft areas.
Old Dec 25, 2013 | 10:41 PM
johns_vette's Avatar
johns_vette
Default firewall
just shot you a PM because I just posted a firewall for a 77 in the C3 parts. I think the 77 would be interchangeable or at least for the splicing on parts. Hopefully someone will be able to tell if there is much difference if you decide to change out completely. If you need to stop by and take a look at feel free, i'm in okc too.
Old Dec 26, 2013 | 07:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My advice is to repair your repairs. Replacing an entire firewall is a major PITA.
Old Dec 26, 2013 | 08:05 PM
lvmyvt76's Avatar
lvmyvt76
Doc's corvettes in Tulsa may have parts that you need.
Old Dec 26, 2013 | 09:08 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Local member has one....I am picking it up saturday!
Old Jan 4, 2014 | 05:04 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Default Firewall
John sold me a great firewall! Local and no shipping!!!
I also now have a new friend that will need help and will help in return, this is a wonderful hobby!!
John also sold me two slotted alum wheels...need three more....anyone have extras???
Old Jan 21, 2014 | 07:30 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Default Hairline cracks
I have been cleaning up the donor firewall, have discovered some hairline cracks. Not sure how to proceed but am thinking of removing about half of the thickness along the fracture and then fill in with fiber and resin...I'm new to glass and really don't want to mess it up.
Once I do one side, should I do the same on the obverse? Also, I found more WHEELS!
Old Jan 21, 2014 | 11:45 PM
johns_vette
Default Cracks
Hey Jerry!
On the cracks, my approach would be to identify if you can fix the cracks after the firewall is installed.
Reason for that is (in my opinion) to keep from adding additional stress. For example, the firewall has not been attached to a birdcage for awhile and sitting around it just changes form a bit. It's really up to you on that but I would mark then install the firewall, then fix all the hairline cracks and holes. Then you know there is no additional stress. Hope that makes sense.
First clean your repair to get the dirt, old glass and debris. I use a grinding disk with about 36 grit and lightly clean up and DO taper out from the crack so naturally you are adding more material. You want it to span a bit. It would not be necessary to fiberglass both sides, just do the one that is easiest to get to. You can either lay fiberglass over the other side, or use filler to make it smooth.
For fiberglass I like to use the Evercoat brand. You can purchase it up on 39th street at B&H paint supply. However it's expensive and uses a cream harder vs. liquid. I have used it for years and it's a personal preference.
Last but not least follow this link to the economy rollers to help work the resin into the fiberglass.
http://www.tapplastics.com/product/s...my_rollers/184
Oh and use fiberglass Mat not the cloth. you can also get heavier mat at the above link.
Good luck!
Old Jan 22, 2014 | 06:25 AM
hereigo's Avatar
hereigo
St. Jude Donor '14
Originally Posted by johns_vette
Hey Jerry!
Good luck!
Thank you John! Great site!
To Replace firewall?
