thrown wheel weight causes damage
Old Dec 26, 2013 | 09:24 PM
mlparsons's Avatar
mlparsons
Cruising
Default thrown wheel weight causes damage
Hey, folks. have any of you ever had a wheel weight fly off and cause damage to your car? I was driving on the interstate the other day and heard a loud CRACK. I pulled off to the side of the road only to discover a sizable dent on my right front fender caused by an impact underneath. At first I thought it might have been a rock or some other road debris until I realized that my newly installed wheel weight was missing. I even have a picture from earlier in the day that shows the wheel weight in place. Apparently It flew off and hit my fender so hard that it cracked the fiberglass and created a 1/4 inch dent to protrude from what was a beautifully contoured fender. Any advice on getting Firestone to take responsibility for this since they installed it less that a month ago? Is this a common issue? thanks!
Old Dec 27, 2013 | 08:13 AM
jnealg's Avatar
jnealg
Good luck proving it was not a rock from the road to Firestone. Who knows when the wheel weight fell off?
Oh I believe you, don't get me wrong but you get my point.
Old Dec 27, 2013 | 08:28 PM
CF6873's Avatar
CF6873
there are about 8 different styles of wheel weights and if the wrong style was used it will not stay tight on the wheel. You may want to check the rest of your wheels and try to determine if they may have used the wrong style weights. If they did you will have more ammo to argue with.
Either way I would go back and see if you can get them to use their insurance to repair the damage.
Old Dec 27, 2013 | 09:53 PM
3JsVette's Avatar
3JsVette
I think it's going to be tuff to prove your case also.
Let us know what happens.
Old Dec 27, 2013 | 11:26 PM
Ratfinkharley's Avatar
Ratfinkharley
That's what happens when you don't go to Sam's Club.
Old Dec 28, 2013 | 01:01 AM
kdf1986's Avatar
kdf1986
I also think it will be hard to prove the damage came from the wheel weight and not a rock or other object.
Was the weight clipped to the rim, or was it attached with adhesive.
kdf
Old Dec 28, 2013 | 08:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Dec 28, 2013 | 11:26 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Touche`:
http://forums.corvetteforum.com/c3-g...65-fuelie.html
Old Dec 28, 2013 | 03:08 PM
The Hot Rod Grille's Avatar
The Hot Rod Grille
2015 C3 of Year Finalist
Another good reason NOT to use wheel weights! I always use Dyna-Beads inside the tire. No ugly weights on the rim, dynamically balances each time the wheel rolls and no problem with lost weights. I just finished restoring my rally wheels and put 4 ounces of Dyna-Beads in each of the new Goodyear Speedway bias plys per the specs for F70-15 tires.
Jim
Old Dec 28, 2013 | 03:20 PM
Karsten's Avatar
Karsten
I was at a friends shop the other day and one of the company trucks had a wheel weight impelled about 1 inch deep in the radiator. Past right through the grill without hitting it and straight into the radiator.
Scary to think if it would have hit the windshield and what would have happened at freeway speed.
Karsten
Old Dec 28, 2013 | 05:05 PM
mlparsons's Avatar
mlparsons
Cruising
Default thanks
Thanks, guys. I did take it back and spoke to the manager (who was very kind and understanding). You're right, even though all signs point to the wheel weight, there wasn't enough substantial evidence to prove that it was indeed the culprit. They did, however, replace all of the remaining wheel weights with the stick-on style which are installed on the inside portion of the wheel. thanks again for your thoughts.
To thrown wheel weight causes damage
