Confused
Old Dec 28, 2013 | 01:18 PM
sullyman56's Avatar
sullyman56
I recently replaced the radiator and found that Bubba had drilled a hole in the fan shroud and wired it to hold it tight on the bottom. Since it was trashed, I replaced that too. I found it actually fairly easy to put in with the fan and radiator removed. During the radiator install, I laid the fan shroud over towards the engine and installed the radiator.
