68E coupe center console question?
Old Dec 30, 2013 | 01:44 PM
13611's Avatar
13611
Default 68E coupe center console question?
Are there center a/c vents on an early 68? Can someone please provide a photo of a 68 center console for my assembly purposes? Thanks in advance, Jason
Old Dec 30, 2013 | 02:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 13611
...Are there center a/c vents on an early 68?...
Early or late makes no difference. All the factory AC cars have the center air outlet vents at the top of the center cluster. For 68, the vent set up is one year only and changed with the 69 models.
All non-air cars got the CORVETTE plate.
...Can someone please provide a photo of a 68 center console for my assembly purposes?...
68 4 speed with factory air. TH400 would be the same with the excepton of the shifter and the shift pattern, both of which will swap between console trim plates.
