Garage pit cover
Old Jan 2, 2014 | 03:50 PM
naasaa's Avatar
naasaa
Default Garage pit cover
Hi all
Currently I have my pit covered with plywood, painted same color as the garage floor.
From time to time I need to relocate a car in the garage, hence roll over, or rest, on top of a plywood plate.
Obvious it is sagging.
I want to fabricate new covers which are able to support the weight of a car in a more safe manner.
In top of the inner wall to the floor, I have a frame of angle iron. 35 x 35 mm app. 1.4" x 1.4"
Anyone in here who can chime in with a great idea or solution?
Lars
Old Jan 2, 2014 | 04:15 PM
The Punisher's Avatar
The Punisher
Originally Posted by naasaa
Hi all
Lars
1/2" diamond plate
Old Jan 2, 2014 | 04:23 PM
naasaa's Avatar
naasaa
Originally Posted by The Punisher
1/2" diamond plate
Is diamond plate these aluminum plates with kind of textures on top?
Old Jan 2, 2014 | 04:24 PM
noonie's Avatar
noonie
We used to use 2x8s over a 4' wide pit and drive onto them with no problems. You could also remove as many or as few as needed.
Old Jan 2, 2014 | 05:09 PM
Jack605's Avatar
Jack605
Any piece of steel would have to be at least 1/2" or it to will sag and it will not spring back, also a steel plate of that size 1/2" thick will be very heavy. I would go with the 2x8 wood, plenty heavy to hold up the car when you have to move across but light enough to remove easily.
Old Jan 3, 2014 | 10:30 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Hi Lars,
Are you doing the work yourself or are you planning to have someone else do it?
How about fabrication tools? Iron will need to be cut to size before welding together and to manage weight, it could be done in same sized sections. Still strong but you don't need to be Hercules to move it, if it was one piece.
Wood also needs to be cut to fit but may be more affordable and easier to source. Making same sized sections there could also work.
Good luck and be safe, whatever you do.
Old Jan 3, 2014 | 11:46 AM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
You could cut steel checker plate into sections to cover the opening to make it easier to remove in smaller pieces or you could use aluminum checker plate with angle iron stiffeners stitch welded to the under side of the plate.
Old Jan 3, 2014 | 01:23 PM
Ontario73's Avatar
Ontario73
I have seen many installations using 2x lumber, but, it does wear overtime and doesn't look that great if your 'man cave' is well appointed.
Personally, I would consider using aluminum checker plate (polished) with stiffeners welded on the underside. The surface is smooth and can be made in sections as large or as small as you like. In my industry we have manufactured many chamber access lids that are rated for semi truck traffic on roadways like this. For a 4' span all you need are 4" deep ribs spaced about 6" apart to hold up to just about anything parked on top of it!
Old Jan 3, 2014 | 02:21 PM
Redwing01's Avatar
Redwing01
For an even "Cooler" look and full view of the pit below go with 1-1/4" bar grating.
To Garage pit cover
