let talk about head lights
Old Jan 9, 2014 | 09:41 PM
Blame's Avatar
Blame
Default let talk about head lights
Yes I really have search, I know it hard to believe but it happen.
I'm wanting to remove my vac line fed head lights, but im leaning to the none pop. I would not mind going electric head lights but not sure which would be worthwhile for me.
So, let talk about headlights.
None pop up: recess or non recess
Pop up: what would be the easiest
Bulds: standard vs HID
Old Jan 9, 2014 | 10:37 PM
M A Fry's Avatar
M A Fry
G'day Blame,
Check out this post in the tech section - http://forums.corvetteforum.com/c3-t...c-new-way.html
Old Jan 9, 2014 | 10:43 PM
alconk's Avatar
alconk
I just don't think a Vette is a Vette without pop up headlamps. Just my .02, I converted mine to electric and am very happy with them.
Old Jan 9, 2014 | 10:53 PM
M A Fry's Avatar
M A Fry
Soooo does that mean they didn't make a real corvette untill 1963 and then stopped making them in 2005?
Old Jan 9, 2014 | 11:05 PM
n.g.hayes's Avatar
n.g.hayes
I went the electric route and it was a pretty easy set up for myself. Car is still in restoration but headlights are done and work better than any vacuum set up. There are a couple of good postings on this forum that will handle all your questions. The Mazda Miata motors work great and are cheap at any junk yard or recycle center, whichever is politically correct for this website.
Norm
Old Jan 9, 2014 | 11:20 PM
Blame's Avatar
Blame
Norm
I seen it done and read about it. Im only concerned about if I get bad motors or I get the set up to find out I got missing piece or broken.
Old Jan 9, 2014 | 11:23 PM
Blame's Avatar
Blame
Those 2005 and up are not real vettes. There to spaces, none popping up headlights, with a huge butt lol jk. Wonder if I can fit the 2005 headlights in to my vette.
Old Jan 9, 2014 | 11:28 PM
Blame's Avatar
Blame
G'day Blame,
I saw that post before or one like it. It that post that kept me from going none pop up. Im on the ropes because im unsure which would be best for short and long term.
Old Jan 9, 2014 | 11:31 PM
Blame's Avatar
Blame
I replace my water pump fan with 2 electric fans so im not worried about making something to hold or make it all work.
Old Jan 10, 2014 | 12:43 AM
alconk's Avatar
alconk
Like I say just my .02. I personally prefer the hideaway headlights. Don't care for the C5s but would really like to have a new C7.
Old Jan 10, 2014 | 01:27 AM
Sunstroked's Avatar
Sunstroked
Ultimately it's your choice. I've seen a few fixed recessed headlite conversions that look ok on the rubber front bumper cars. I think the chrome bumper cars look better using a pop up. My self I'm in the process of doing the electric conversion. I have most of the parts and only have $125 into it.
Old Jan 10, 2014 | 06:19 AM
billcarson's Avatar
billcarson
MA Fry ,yes before '63 they didn't know any better and in 2005 the government decided pedestrians would be injured more seriously when struck by the raised headlights.you all know i don't make stuff up.
Old Jan 10, 2014 | 06:24 AM
oldgto's Avatar
oldgto
I`m going with electric.... headlights AND wiper door. I already have the Miata motors, and I`m working on an aluminum bracket. For the wiper door, a 2004 Malibu seat motor is what I`ve seen used, so I got one of them too.
Old Jan 10, 2014 | 08:57 AM
Blame's Avatar
Blame
How strong would I need to make the brackets if I go with a electric motor? Im starting to lean to electric again. Wonder if ill still be ok with my 100amp alternator.
Old Jan 10, 2014 | 09:50 AM
John 65's Avatar
John 65
I found a piece of aluminum on ebay, then cut it into sections for several brackets when we made mine. Its 1/4 " thick but it don't have to be anywhere near that strong. Your current alternator is plenty. They are soooooo much less expensive than those 2 jackstands that they sell as a kit. Just for the record, a properly working stock vac system is hard to beat, but my 77 is just a toy, and this was a fun and inexpensive project that really works great.
Old Jan 10, 2014 | 10:52 AM
Richard454's Avatar
Richard454
The headlight motors pull about 7amps to lift/close- draw is just a second or two-so no problems w/ current draw
This or this? You get to neaten up the engine bay...
Here's a 'How to' - I put together.
http://forums.corvetteforum.com/1585751664-post705.html
I have both steel and stainless brakets made up- Just PM if interested.
Richard
Old Jan 10, 2014 | 11:05 AM
Sunstroked's Avatar
Sunstroked
While I agree that a properly functioning vacuum system does the job, the big vacuum lines and tank clutter up the engine bay. Just fine if you are doing factory restoration. But if you are trying to clean up the bay they have to go.
I attend a lot of car shows. The cluttered engine bay of our C3's really look crappy compared to other factory cars of the day. In fact I'm going to say the C 3 has the worst looking engine bay of any corvette made.
To let talk about head lights
Old Jan 10, 2014 | 11:51 AM
Blame's Avatar
Blame
I agree with that. After deleting the wiring harnesses to my motor then remove the air pump and none needed vac lines removed fan to add a duel electric fan. When I finish building my 383 lr1 carb motor im going to build a race way to hide the wires better.
Old Jan 10, 2014 | 01:17 PM
Ratfinkharley's Avatar
Ratfinkharley
Aesthetics aside, if that was how it was built then that is what appeals to me at car shows. I am of the opinion that stripping things off or modernizing removes character. I do applaud creativity and ingenuity.
Plus I like the way my 73 "winks" at me for a bit before we go for a night ride.
Old Jan 10, 2014 | 02:21 PM
alconk's Avatar
alconk
The only reason I converted was I could not raise the headlight with the car not running. Every piece of vacuum system was brand new too. If would hold vac about about 15 minutes and that's it. But during that 15 minutes I would only be able to raise maybe one headlamp door and that wasn't all the way up. Electric, washing the car piece of cake go in and hit the over ride switch lights come up. Hit the switch again light go down. Very very nice. And I owe all my thanks to the nice people on this site for making it happen.
