Purple Power
Old Jan 17, 2014 | 07:07 PM
MrJlr's Avatar
MrJlr
Default Purple Power
Purple power works GREAT!!!
2.5 gallons for $13.97 at Pep Boys.....running it full strength.
Really cleaning up my aluminum intake, water pump and everything else! !!!!
Old Jan 17, 2014 | 08:14 PM
chevygod's Avatar
chevygod
The stuff is bitchin' but do where gloves when using it as it will seriously mess up your skin. Pulls all of the oils out or some such.
Old Jan 17, 2014 | 08:21 PM
MrJlr's Avatar
MrJlr
And safety glasses
Old Jan 17, 2014 | 08:25 PM
imariver's Avatar
imariver
I like that purple stuff from ZEP, it not only does a good job of de-greasing you car parts, it works great on the wife's pots and pans!
Old Jan 17, 2014 | 08:32 PM
MrJlr's Avatar
MrJlr
Hey......long time no see!
I pulled my engine. My 383 stroker will be here Tuesday
Getting her ready for our cruises!
Should be back on the road in 4 to 6 weeks!
Old Jan 17, 2014 | 09:26 PM
oldschoolvette's Avatar
oldschoolvette
Originally Posted by MrJlr
And safety glasses
Old Jan 18, 2014 | 09:54 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Does it work better or just as good as Varsol?
Old Jan 18, 2014 | 10:49 AM
Patro46's Avatar
Patro46
You using it full strength?
Old Jan 18, 2014 | 10:53 AM
MrJlr's Avatar
MrJlr
Yes! Really cuts grease
Old Jan 18, 2014 | 10:54 AM
MrJlr's Avatar
MrJlr
Cant really say.....never used that product. ?.
Old Jan 18, 2014 | 02:52 PM
68L79's Avatar
68L79
I have used it on 3 cars that were basically frame off to remove rust...works great for that as well as greasy parts...just use full strength with a small wire brush....really helps remove the rust...again...like everyone says...will burn your hands if you get it on them...especially if you have a cut.
Old Jan 18, 2014 | 04:34 PM
chevygod's Avatar
chevygod
I have noted it removing some light rust, didn't want to mention it cuz I thought it was just me. Didn't work on really heavy stuff, but was great on light serface oxidation on suspension and steering parts. Also really cleans that baked on ugliness on internal engine stuff. For really bad stuff I use carb dip, rinse, and the then the Purple Power. Sometime will attack aluminum, so be aware.
Only thing I have found that was better was called Come Clean by Castrol Industrial. Nasty stuff, FDA and EPA compliant. Will heavily discolor paint and attack aluminum, but removes the worst grease, tar, varnishes, and oils. Dip piston/rod assemblies in it and they come out looking like new rods with white satin pistons. I <think> Castrol Super Clean is a diluted version. Purple Power was in my experience better than the Super Clean.
Forgot about the safety glasses, but I usually wear those for everything I work on, at home and at work, anyways, so slipped my mind.
Old Jan 19, 2014 | 09:24 AM
imariver's Avatar
imariver
Just can't leave it alone can-ya . . . . .
Speaking of cruises . . . I haven't heard anything about them. Is anyone doing any planning?
Old Jan 19, 2014 | 10:14 AM
MrJlr's Avatar
MrJlr
I talked to Paul the other day. He is just getting back on his feet after a knee surgery.
We definitely want to set up a Solvang cruise
But there will be many cruises to plan still!
New engine, I gonna want to drive her!
To Purple Power
