October 69 build date, what would engine date range be?
Old Jan 27, 2014 | 09:11 PM
Northern Corvette's Avatar
0Northern Corvette
Former Vendor
Default October 69 build date, what would engine date range be?
Have an October 69 built car, and engine block and heads are all dated k228, and k108 for block. Is this date range normal? November of 68 I believe the dates would be, so 11 months before build date. Is this normal, and would be ok for ncrs? I thought ncrs had 6 month rule? Stamp pad and vin are both mid October 69.
Old Jan 27, 2014 | 10:26 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Hi, I am by far no expert but I'd say Nov 68 for an Oct 69 build is a bit out of whack. It's a 400hp car right? Do you have a picture of the stamp pad you could post? Are the casting dates clear enough that you are certain they are K**8? I've seen 9's that have looked like an 8 at first glance (though Nov 69 would really be wrong). The block and heads seem to jive with each other, just not for the car. I assume the block casting # is correct?
As far as NCRS goes, I believe 6 months is the guideline. Anything outside that would be suspect and would probably require some sort of proof (just guessing, there are a few judges here that would know). Even though there is a 6 month guideline, most cars, barring any strikes or other circumstances, are closer to the build date than that.
Try to post a clear picture of the stamp pad.
Old Jan 27, 2014 | 10:35 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I am assuming small block based on those casting dates.
The NCRS Judging Guide states, "The engine casting date must precede the engine assembly date, and both must precede the vehicle assembly date by no more than six months."
Typical production is 2-8 weeks.
I would expect a deduct for not typical.
The date code can also be seen through the oil fill cap, so I would expect a deduct as well.
EDIT: Seems John did a bit more research into your car. You cannot see the date code on the big block heads; therefore, the casting number or date is not judged.
Old Jan 27, 2014 | 10:43 PM
JimE's Avatar
JimE
I agree with avalonjohn, not impossible I guess, but certainly not typical. Usually casting date to assy is much less than 6 months, but the NCRS will use 6 months as a guide line. I would like to see good pictures of the pad.
Old Jan 27, 2014 | 11:32 PM
0Northern Corvette
Former Vendor
Pics
Old Jan 27, 2014 | 11:34 PM
0Northern Corvette
Former Vendor
Pics
Old Jan 27, 2014 | 11:40 PM
0Northern Corvette
Former Vendor
Block
Old Jan 28, 2014 | 06:27 PM
0Northern Corvette
Former Vendor
Pics posted
Old Jan 28, 2014 | 06:43 PM
Alan 71's Avatar
Alan 71
Hi nv,
I'm surprised at the random spacing of the digits on both the assembly stamp and the vin derivative stamp.
Since they were done at 2 different locations wouldn't at least one of them have been done in a gang holder?
What's the pad surface like under that paint? Any indication of a "factory grind-out"?
Regards,
Alan
Old Jan 28, 2014 | 06:46 PM
0Northern Corvette
Former Vendor
Originally Posted by Alan 71
Hi nv,
Regards,
Alan
I'm not sure. Maybe someone else can chime in? The motor wasnt in the car and was actually in 2 different locations, so it wasnt someone faking it to sell the car. Unless it was done a long time ago then taken out of car?
Old Jan 28, 2014 | 06:49 PM
Mike Ward's Avatar
Mike Ward
Pics
That's not a factory stamp.
Can't read the casting date on the block. Most digital cameras have a macro setting that allows crystal clear close up pics.
Old Jan 28, 2014 | 07:12 PM
0Northern Corvette
Former Vendor
Thanks mike, I'll stay away from it then. Dates seemed off, just not sure why someone would have stamped the pad with those numbers? The motor and car are being sold by 2 different people hundreds of miles apart who don't even know each other, I sort of stumbled on the car after looking at the motor. Is the vin AND the engine jnfo and suffix both bad, or just the vin part? Just trying to learn, thanks again
Old Jan 28, 2014 | 07:29 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
NC, It could just be me but the VIN especially looks strange. To me, the font seems to be too big, maybe it's just the angle. Other things like, as Alan suggested like the spacing. Carefully (no abrasives) take call the paint off the stamp pad and take another picture.
Strange that they are being sold separately by two who don't know each other.
Old Jan 28, 2014 | 07:40 PM
Mike Ward's Avatar
Mike Ward
Nothing on that pad looks factory. That plus the weird dates= Run Forrest.
Old Jan 29, 2014 | 09:11 PM
JimE's Avatar
JimE
Unless the lines I'm seeing on the pad are just in the paint, my opinion would be that the pad has been remachined. The machining lines, or broach marks which is what they are refered to, should run parallel to the center line of the block, (back to front). The broach marks may be heavy & very pronounced or rather faint, I've seen both, depending on when they changed their tooling at the plant.
Old Jan 30, 2014 | 11:41 AM
joewill's Avatar
joewill
I expect your motivation is to try an re-unite the motor and the car back together.. not worth the effort in this case.. that is not a gang stamped pad, fonts are wrong, spacing is wrong, check casting number, it may not even be a 512 block.. can't comment on the broach marks since the pad is painted, but I expect that if you did clean off the paint, there would be no marks, or swirleys will be there.
I bet that engine and car were indeed once united, but badly stamped to make it look original to the novice buyer.
2 to 8 weeks would be more normal, 6 months is extreme, and 11 months is ultra extreme.
scenarios exist where it could be the original engine to the car, but those excuses won't fool a knowledgeable buyer.
interesting find though.
To October 69 build date, what would engine date range be?
