I have gotten everything set up on the distributor except the two wires going from the wiring harness to the distributor. The wires are a tan and a orange and will plug up ether way so I'm not sure which wire goes to which side.
Unless it's changed, your tach should be mechanical.
On my 73, the two wires from the harness go on the + coil post.
The wire from the coil - post should go on the distributor.
Mine is a black wire from starter and cloth braided one from
ignition switch.
Donnie
