74 vette bulb change
Feb 8, 2014 | 01:39 PM
How do you change rear backup bulb on a 74 vette? From the outside or underneath. Thanks. Bill
Feb 8, 2014 | 01:57 PM
Feb 8, 2014 | 02:01 PM
Quote:
Originally Posted by
outlawkinser
Underneath!
Mike
Is it hard to get to it?
Feb 8, 2014 | 02:07 PM
llabesab7
Not really. Only takes about a quarter turn to loosen it. If the bulb holder hasn't been off in some time, it can be hard to turn. The last time I changed one of mine, I used a channel lock pliers to grab it and turn.
Mike
Feb 8, 2014 | 02:56 PM
Feb 8, 2014 | 05:13 PM
when my 74 is turned off should my oil gauge go back to zero?
Feb 8, 2014 | 06:08 PM
Feb 8, 2014 | 06:26 PM
llabesab7
I would say yes.
Feb 8, 2014 | 09:17 PM
I do not think it goes to zero when you turn it off. But when you turn on the ignition ACC it should go back to zero.
Feb 9, 2014 | 10:06 AM
swensonm
Feb 9, 2014 | 10:20 AM
Cruise-In II Veteran
llabesab7
Crawl under and take a look. You need to be able to get a hand up under there.
Feb 9, 2014 | 10:40 AM
Easy Mike
Have the band-aids ready.
