How do you pull your engine...headers on....trans on?
DJ Freddie
I just pulled my BB- just dropped the headers back and pulled the trans- never touched the hood or core support. I did pull the distributor and carb, but that was as much to just get it out of the way as anything. Getting the distributor out is an easy way to make sure that it won't get broken.
Obviously, many options are available, when doing this job. I wouldn't even start until I have ample work space to disassemble, catalog, and organize.
As also mentioned, I remove the hood, distributor, and carb to protect them and gain more work room.
I work indoors unless I have my tracked bucket loader available.
I prefer pulling the engine and trans as a unit. In my experience, it solves a lot of alignment issues on reinstallation but that's just me.
Factory clutch cars have a fixed (welded) trans crossmember; automatic-equipped cars are removable. That'll make a difference, too.
Whatever you do, be safe. That's a lot of weight you're dealing with and accidents happen. I try not to be one, mostly due to working alone. For the less experienced, it never hurts to have good help available.
I drain the coolant at the pain rail plugs. I always install petcocks to all my engines to simplify that process. Then I drain the rad.
A lot of the effort required depends on whether one is working with the stock configuration or a car that has been "modified". My definition of modified: having removed previously installed OEM-type equipment; ex.: if your car has a fan shroud, A.I.R. pump and hoses, lower ignition shields, or any AC equipment.
Because I do not have a lift to access from underneath, I raise the car on jackstands, crawl on my back, and prepare by disconnecting the exhaust, driveshaft, gear shifter, clutch-linkage, cables, hoses, and removing the starter. I like removing the radiator to make sure I don't unintentionally punch a hole in it (been there, done that).
I prefer to remove headers/exhaust manifolds for added room. They're easier to remove/replace at that stage too. I've had the mech fuel pump cause interference so I remove/install while the engine is on its mounts.
I have scratched up painted panels in the past. Now-a-days, I throw blankets or some sort of shields to protect them from accidents. Blankets or fender covers make a convenient place to hold tools.
I employ a leveler on my cherry picker's hook and approach from the side.
Once you remove/replace an engine, you'll figure out what works best for you. I'm lazy so I like to clear as much space as possible to save unintended consequences. Too many Benjamins are spent and I only have so many to enjoy. Besides, I hate rework.
Good luck and let us know how you do.
Also - My headers are welded to my exhaust pipes, which can lead to obvious problems pulling the motor. If this is the case for you, unhooking the exhaust hangers on the mufflers and at the crossmember first will allow you to rotate the headers away from the motor.
Good luck!
I Like to leave the trans behind, so as not to mess with all the spilled oil out the tail shaft, and if the car has a/c the condenser up front is still in the way to not allow the tailshaft clearance off the firewall, meaning it's tail down on the way out/in.....with the typical lift like I have, it's much easier.....
