Electrical wizards....Multimeter
Old Feb 21, 2014 | 11:04 AM
Kevin68's Avatar
Kevin68
Default Electrical wizards....Multimeter
Any recommendations for a good multimeter for automotive use? I currently () need it to track down a short(s), but will want it to do anything I might need on the corvette. My existing meter is a POS.
Is a Fluke 88V more than I need? The RPM feature is attractive.
Kevin
Old Feb 21, 2014 | 11:12 AM
qwank's Avatar
qwank
i use a Fluke 87V. the 88 should be fine.
Old Feb 21, 2014 | 11:34 AM
jcloving's Avatar
jcloving
Please post pics and links for these. I have been considering a multimeter purchase.
Old Feb 21, 2014 | 11:44 AM
C3Hawk's Avatar
C3Hawk
I have the Klein MM200. Home Depot sells it. I think at $100 it's a good reliable meter priced right in the middle between the cheapos and the Flukes.
Old Feb 21, 2014 | 11:47 AM
7T1vette's Avatar
7T1vette
For performing DC electrical and continuity checks, about ANY multimeter will work fine. If you start checking into electronic circuit testing, that Fluke meter should be able to handle about anything you throw at it. But, with any 'gauge'/'tester', you have to use it properly.
Old Feb 21, 2014 | 12:23 PM
MIKE80's Avatar
MIKE80
I have a Fluke 115. Nice having the backlight feature
http://www.amazon.com/Fluke-115-Compact-True-RMS-Multimeter/dp/B000OCFFMW http://www.amazon.com/Fluke-115-Compact-True-RMS-Multimeter/dp/B000OCFFMW
Old Feb 21, 2014 | 01:32 PM
Gordonm's Avatar
Gordonm
I have I think 5 multi meters. Everything from a Fluke to a free meter from Harbor Freight. Honestly for checking most things on the car the Harbor Freight one does as good as the Fluke. When you get into more circuitry yes the Fluke is the way to go. I have them scattered around the garage and my truck and usually just grab whichever one is closer.
Old Feb 21, 2014 | 01:38 PM
mrvette's Avatar
mrvette
I have had Fluke meters for decades, gave one to my son, deadly accurate....and reliable, but in all honesty, I have a RED Harbor Freight cheepie in the vette for backup.....carried in the center hutch....
but I have FI and an extra computer in the car also....just because....
Old Feb 21, 2014 | 01:50 PM
texbeasr3's Avatar
texbeasr3
If your chasing shorts in the wiring, use the meter to montior the current drain from the battery. You will need to put the meter in current mode and in series with the battery.
As you pull fuses or check wiring, note the changes in current to see if current reading go down.
Old Feb 21, 2014 | 03:29 PM
Kevin68's Avatar
Kevin68
Yes, this is the procedure I have used. With my current cheapie meter, I get a null current draw with the clock disconnected. Since I know I have a draw somewhere I reconnected the clock as a check and it didn't work and had no draw (with the meter in series). I came to the conclusion that the meter is fried.
It also shows my alternator is putting out 17.5 volts. When I had it checked, the parts house said it was putting out about 14.5-15 volts. The guy was nice enough to switch the leads on his tester so he could get a "fail" test result on it and give me a new one. I replaced the alt. and regulator and got 17.5v again. Tough to run down these problems without confidence in my meter.
Old Feb 21, 2014 | 04:15 PM
qwank's Avatar
qwank
what does the battery read fully charged when the engine is not running?
Old Feb 21, 2014 | 04:34 PM
Kevin68's Avatar
Kevin68
As best as I can remember it was about 12.7 or 12.8. The battery is 5 years old.
Old Feb 25, 2014 | 10:53 AM
texbeasr3's Avatar
texbeasr3
Last short I chased was caused by the Alarm wire on the door switch. It had broken off and was intermittent to gorund causing about 100mA draw on the battery. After I fixed it the current draw was 10mA or less. So insure your meter is set to read small current values. I used a cheapy Harbor Freight meter.
To Electrical wizards....Multimeter
