Question On C3 Fuel Tank
http://www.spectrapremium.com/products/fuel_tank.html
I have a Spectra replacement tank, here is a pic of it during the conversion to an in-tank EFI pump:
I've got the very first tank they made for '73s. Their factory is just down the road from where I worked.Lots of C3 Corvette parts are/were made in Canada. The 'made in XXX' laws don't go back far enough to capture every example.
1) The vent nipple on the driver's side remains, and is used as intended. The return nipple on the passenger side was removed, and the hole welded shut.
2) The cutout is at the deep side of the tank. It is a stainless steel fuel pump/sump kit from Rock Valley. It cost $375, which included the Walbro 255 LPH pump, and is very well made. It is made to fit right into the stock tank. If my tank wasn't basically brand new, I would have went with the complete Rock Valley SS baffled tank and fuel pump/sump. I had my local race shop weld it in my tank for me, then I custom bent SS hardlines for it. I then painted the tank. Some more pics:
Here is my tank installed in the car:
No problems with this set up after a almost 4yrs of use. The pickup has never gone dry under any situation, and I have ran it almost completely empty a few times; once less than 1 gallon in the tank!
Thanks,
Danny
First I went over the tank with a red Scotch-brite pad, then I sprayed it with self-etching primer; you need to use the etching primer because the tanks are made with Ni-Terne steel. For the final coats, I used Duplicolor #DE1650 Cast Coat Aluminum. I made the anti-squeak strips out of a self-adhesive waterproofing membrane product called Blueskin.
