Engine ID question
Old Feb 28, 2014 | 06:12 PM
Nola69's Avatar
Nola69
Navigator
Default Engine ID question
I have a 69 convertible, and was looking at the engine code (right side front of engine) and saw the stamp of CEOA488 59. Does anyone have any idea what the heck this is? I know its a small block, but cannot find any info about it. Thanks in advance!
Old Feb 28, 2014 | 06:50 PM
Mike Ward's Avatar
Mike Ward
CE is Chevrolet Engine. 0 is for 1970. The rest is a sequential serial number that is not tied to engine config. or horsepower.
It's an over the counter replacement or warranty short block.
Old Feb 28, 2014 | 10:08 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Hi Nola,
In your case, it might have been installed as a warranty replacement. Do you know what your '69 originally came with, the 300HP or 350HP small block? There are some indications (like tach redline, console plate) but these can be changed out. Or any original documentation (POP, tank sticker)?
This would give you a more educated guess as to what the engine could be, but you will not have full knowledge of the rotating assembly unless you decided to crack it open.
Old Mar 1, 2014 | 09:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The block casting number might help identify it.
Old Mar 1, 2014 | 11:32 AM
pacecar620's Avatar
pacecar620
About the only way to tell what you got lurking there is pull the pan and peek at the main bearing caps. 2-bolt would be lo-po or base engine, 4-bolt likely a 350/350 replacement. Maybe head casting #'s could provide some clue as well.
Old Mar 1, 2014 | 06:49 PM
Nola69's Avatar
Nola69
Navigator
Thanks a bunch guys. Pacecar the heads are not stock, they replaced the stock heads with double hump heads. Thanks again, as I learn new things here every day!
Old Mar 2, 2014 | 06:44 PM
gregk1's Avatar
gregk1
i have some questions on an engine i bought today pad#CBE1913 80/ 350 4 bolt 0010 block with date code G-2-1 forged steel crank pink rods windage tray and large corvette pan with trap door 8" balancer pistons are#3959456 heads are 492 angle plug intake is 3972110 carb is holly# 4779-2 /2784 cast iron dizzy no tack drive and no # would this be a warranty replacement /crate motor also it seems to be LT1 for the most part ben sitting for over 20 years
Old Mar 3, 2014 | 04:27 PM
Nola69's Avatar
Nola69
Navigator
I checked and the block casting number is
28GM
3970010
Thanks,
Tony
Old Mar 3, 2014 | 04:31 PM
Nola69's Avatar
Nola69
Navigator
28GM
3970010
Thanks,
Tony
And then I found the information that I was looking for! Sorry for the bother, next time I need to search deeper before asking questions.
Thanks again for the replies
Old Mar 4, 2014 | 06:50 AM
Easy Mike's Avatar
Easy Mike
...3970010...
Generic 350 CID block. There are millions of them.
To Engine ID question
