Looking for a drivers side shoulder belt for my 1971 coupe. Interior is black. All that is there is the plastic casing. That way when I bought it. Any info would be greatly appreciated.
I don't have a clue as to what you are asking. The only 'casing' for the shoulder belt is the retractor housing that is mounted to the rear wheelwell hump and the short vinyl cover over the buckle end.
I am getting that he is looking for the belt with retractor assembly? clarification would be helpful.....I know they make some pretty correct GM replacements now as a full set for like $350 and also can buy direct fit complete sets for like $150 $175...if you post in the wanted section, you likely can find the single shoulder/retractor/belt assembly you need...if that is indeed what you are looking for
That is exactly what I am looking for. Posted in that other section & got no response, that's why I was reaching out to you guys. Do not want to buy all new belts as the others are original & there is no need.
