New Surface Rust - WTF?
Old Mar 22, 2014 | 04:11 PM
cicconjo's Avatar
cicconjo
Default New Surface Rust - WTF?
I live in MA and, as always, have kept my '69 garaged and covered all Winter. Never out in rain or salt. Took the cover off today for first start-up and noticed surface rust over many engine parts, mostly new ones, including air cleaner cover, master cylinder, dipstick, booster, ignition shielding bolts, and a few lines. Nothing major, but still concerning. I don't think the garage is excessively moist - actually it's a new home, although there is a pool next to it (outside) and some rooms below. Not heated or cooled. Wondering if this is a matter of crappy replacement parts or something I did wrong. Like I said, never happened before.
Any ideas?
Old Mar 22, 2014 | 04:49 PM
Paul L's Avatar
Paul L
Any ideas?
New concrete floor gassing off with non-breathable car cover. Just a thought.
Old Mar 22, 2014 | 04:53 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Is you garage well insulated (floor, ceiling, walls and door) and is it sealed? Most surface rust is caused by humidity....moist air condescending on cold metal parts. Also unless you put down a vapor barrier on the floor moisture can come up from the concrete and cause surface rust.
Old Mar 22, 2014 | 06:34 PM
Ridgerunner001's Avatar
Ridgerunner001
If you store pool chemicals in garage or getting humidity from pool they will off gas and cause all kinds of issues.
Old Mar 22, 2014 | 06:43 PM
jlaw68's Avatar
jlaw68
A friend kept his pool chemicals on one side of his garage and his Harley on the other side. After last winter the front forks, wheels and a lot of the motor parts had corroded and started to rust. Keep your pool chemicals in a storage shed by themselves.
Old Mar 22, 2014 | 10:27 PM
7T1vette's Avatar
7T1vette
NEWS FLASH!!!!
There is water in the AIR!!!
If you don't want bare metal parts to corrode/rust, paint them, plate them or coat them with something that impedes moisture. I have done my very best to make sure that there are NO bare metal parts remaining when I refurbished my engine compartment.
Old Mar 22, 2014 | 10:38 PM
80Baby's Avatar
80Baby
Originally Posted by 7T1vette
NEWS FLASH!!!!
Old Mar 22, 2014 | 11:25 PM
MakoJoe's Avatar
MakoJoe
WD-40 will help but you do live in a high humidity area of the US where 60% to almost 80% humidity year round. I live in Colorado and coat my parts down with WD-40 when I go to put the car to bed every winter and I am in an area that that generally stays between 15% to 40% year round unless it rains.
http://www.currentresults.com/Weathe...y-by-month.php
Old Mar 23, 2014 | 12:38 AM
my 76 ray's Avatar
my 76 ray
My brother-in-law had a new garage built last summer and he put a cover on his Vette. Fortunately, he went to show the car to someone and when he took the cover off everything was really wet under it. Needless to say, he took the cover off for the winter.
Old Mar 23, 2014 | 01:04 AM
ctuinstra's Avatar
ctuinstra
Condensation is one of the biggest causes. If the car is cold and you open the garage door on a nice warm moist day, the car and everything abut it will condensate and rust. I learned this the hard way with some tools in my garage when I was younger. Keep the doors closed until the temps are closer or the other way around.
Old Mar 23, 2014 | 08:58 AM
SIXFOOTER's Avatar
SIXFOOTER
you need a dehumidifier of some sort in there.Used to be a gizmo called a "Goldenrod" I think it was, was made specifically for vehicles stored under a cover to keep moisture out.
found a link
http://www.goldenroddehumidifiers.com/
Old Mar 23, 2014 | 09:31 AM
cicconjo's Avatar
cicconjo
found a link
That's pretty slick. Thanks for the link. This is something worth looking into, along with some sort of dessicant.
I don't think the issue is pool chemicals or lack of sealant, as the only thing different this year was the use of a car cover, which is supposedly "breathable." Ordinarily I do not cover the car as it does not really accumulate much dust. Just wanted to preserve the detail job.
I think next Fall the plan will be to leave it uncovered, possibly with the hood cracked slightly, and possibly the dehumidifier/dessicant.
Perhaps the lesson to be learned here is sometimes overkill can be the enemy.
Old Mar 23, 2014 | 09:44 AM
The Punisher's Avatar
The Punisher
I don't use a car cover in the garage. I agree with another member who said to watch outside temp to garage temp.
Old Mar 23, 2014 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
NEWS FLASH!...There is water in the AIR!...
Yep. Everywhere. As Neil Young put it, Rust Never Sleeps.
Old Mar 23, 2014 | 10:38 AM
jhudec's Avatar
jhudec
I have used the car capsule the last 2 winters. I picked one up here from another forum member at a good price. It has a fan that keeps air circulating around the car. Second winter now and my garage gets very moist in the winter.
No rust on any parts!
Old Mar 23, 2014 | 10:49 AM
ctuinstra's Avatar
ctuinstra
He is a great example. Back then I had just a pole barn, I walked in and saw the tires on my tractor dripping with water. I don't mean just moist, I mean water streaming off the rubber tires; but only 3/4 of the way up the tire. Those tires are filled with fluid for ballast and that fluid was very cold from the night before. That morning it was warm and humid out. The cold fluid caused the tires to condensate just like a ice cold glass of water.
The little warming rods and bags of desiccant will do NOTHING for you in such a large area unless you have the car sealed in an airtight bag.
Old Mar 23, 2014 | 12:00 PM
ChuckWalters's Avatar
ChuckWalters
I have used the GoldenRod Dehumidifiers in my gun cabinets for years. They work very well! Should work well for your car too!
To New Surface Rust - WTF?
Old Mar 23, 2014 | 12:05 PM
7T1vette's Avatar
7T1vette
They would work....IF you 'bag' the car.
Old Mar 23, 2014 | 05:04 PM
Mark G's Avatar
Mark G
I agree with everything the others have said. A new house could have greater humidity too. Concrete isn't a moisture barrier so any humidity coming from below will come straight up to the car. I'd store it uncovered with the hood popped up and see how that goes. Or, put a thin sheet over it, something that will allow air to 'breathe'. New plating these days isn't generally very good either.
Get a Relative Humidity sensor to put out there too and record your RH's.
Old Mar 24, 2014 | 12:27 AM
7T1vette's Avatar
7T1vette
Many years ago, at the GM plant where I worked, we were getting ready for our Christmas break. Some "whiz kid" got the great idea to let the temperature in the plant drop (a bunch) over the holidays so that a bunch of money would be saved from using less fuel to heat it. Since only the Patrol folks would be there, no big deal.
Well, holiday break was over and we all went back to work. Only problem...most of the expensive STEEL gauges and tools in the place had gotten rusty!! Yep, condensation over a 1 week period cost that "whiz kid" a job...and the plant a whole bunch of money to repair all those expensive tools/gauges.
{Rust never sleeps... }
