How do I fix this broken piece
Old Mar 22, 2014 | 07:46 PM
teamo's Avatar
teamo
Default How do I fix this broken piece
The piece that connects the front nose below the cowl has a broken piece. How do I repair this? I was thinking of using some epoxy and grinding it smooth on the edges or fiberglass?
Old Mar 22, 2014 | 10:17 PM
7T1vette's Avatar
7T1vette
The more important questions is "Why is it broken?" That could be a stress crack because the strength of the frame/birdcage is seriously weakened from rust/rot.
Old Mar 22, 2014 | 10:56 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
fiberglass...
But also wondering why it's broken...that's kinda weird.
Old Mar 22, 2014 | 10:59 PM
billcarson's Avatar
billcarson
i agree and that could lead to other more serious problems,so you have been warned.good luck on the repairs.
Old Mar 23, 2014 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Hold on to the piece lying on the cowl in your first pic.
Old Mar 23, 2014 | 11:02 AM
Hpozzuoli's Avatar
Hpozzuoli
Epoxy would probably work for some length of time. I would use glass. It's not overly complicated and if you never worked with glass before this would be the perfect first attempt.
What condition is the car currently in? Is she in resto mode?
Old Mar 23, 2014 | 11:14 AM
teamo's Avatar
teamo
The car is not in running condition right now. I got it from my Brother and it has been sitting for about 25 years. That broken piece has been like that since he got it and it appears that it was repaired some time in the past.
To How do I fix this broken piece
