Won't start. Need some help
Old Mar 23, 2014 | 03:05 PM
tyrant's Avatar
tyrant
Default Won't start. Need some help
My 1969 has been sitting since the 70's. I bought a running engine out of a 1970 vette. It's has a point distributer. I'm getting fuel. Turns over but won't start. It sounds a little off. I checked for spark off of a wire with a plug and got nothing. There is power to the coil at positive side. Where should I start? Doing a frame off and this is the first time it's been not fun in a while.
Old Mar 23, 2014 | 06:27 PM
my 76 ray's Avatar
my 76 ray
Check your point gap/dwell, make sure that none of the wires to the points/condenser are grounding out on the distributor and make sure the timing is right. By that I mean that it's sparking on the compression stroke for #1.
Old Mar 24, 2014 | 11:12 AM
The13Bats's Avatar
The13Bats
With no spark its not gonna start or run so start there, if you can score an old good hei dizzy to test with it's far better than putzing with points...
Old Mar 24, 2014 | 11:51 AM
mikem350's Avatar
mikem350
Good idea..feed it 12 v direct. It would eliminate the coil, ballast, rotor etc. But you would have to mod or swap the plug wires to fit at dizzy.
Check all your wiring again, check balllast, use a test light, key on
Old Mar 24, 2014 | 08:13 PM
tyrant's Avatar
tyrant
Got her running. Rechecked tdc and firing order.Filed down the points and cleaned up the rotor. Thanks for te help
To Won't start. Need some help
