What's this for?
Old Mar 23, 2014 | 05:26 PM
Cavu2u's Avatar
Cavu2u
Default What's this for?
What attaches to this pad?
Old Mar 23, 2014 | 05:31 PM
'75's Avatar
'75
EGR valve, cant run with out it or a block off plate.
Old Mar 23, 2014 | 05:32 PM
thegazman's Avatar
thegazman
Default thegazman
EGR Valve
Old Mar 23, 2014 | 05:46 PM
Cavu2u's Avatar
Cavu2u
Block Off Plate it will be then guys.
Thanks!
Steve
Old Mar 23, 2014 | 06:07 PM
Blue73Shark's Avatar
Blue73Shark
In case you change your mind, round silver object is EGR valve:
Old Mar 23, 2014 | 06:25 PM
Paul L's Avatar
Paul L
Just 1973-74 had that configuration of EGR valve. The usual triangular block-off plate will not fit.
Old Mar 23, 2014 | 06:29 PM
qwank's Avatar
qwank
for that style you'd be better off just putting the EGR valve on.
Old Mar 23, 2014 | 09:10 PM
Cavu2u's Avatar
Cavu2u
I think you might be right.
Used some .130/eighth inch aluminum plate, with cork & exhaust sheet gasket, for fabrication. Bent the hole tab a bit more than the block angle for a tight seal.
I bought this car for a HUGE reason; NO FU*#ING CALIFORNIA SMOG CHECKS. I DON'T WANT ANYTHING ASSOCIATED WITH SMOG CONTROL ON THIS CAR! 20 years living in this Socialist state does this to people.
Ahhhh.....I feel better.
Old Mar 23, 2014 | 09:41 PM
qwank's Avatar
qwank
I didn't say you had to make it functional, just plug the hole with it. I hope your blockoff plate is nice and tight. ANY leaks and your car is going to run like crap.
Old Mar 24, 2014 | 01:35 AM
junkman123's Avatar
junkman123
for a better seal just drill and tap three 1/4-20 holes where i put the black dots
To What's this for?
