68 Speedometer cable confusion
Old Mar 26, 2014 | 09:21 AM
AWilson's Avatar
AWilson
Default 68 Speedometer cable confusion
The old speedometer cable is the red one on the right. (see picture). It seems to be broken. I believe the rest of it is in the back of the speedometer as it looks like there is something red in there. If my assumption is correct, how do I get the piece out of the speedometer? I cant seem to get it out from the back side yet.
( p.s., they look different sizes because one is closer to the camera. But they are actually the same.)
The cable on the left is the new one. It is formed into a square shape at the end. Is this the correct replacement or is it supposed to be red plastic too? If I need the red one can someone tell me where to get a new one. I can't find it in the catalogs.
I appreciate any help.
Old Mar 26, 2014 | 09:36 AM
my 76 ray's Avatar
my 76 ray
It looks like the end of that red one might have been a long square shaft like the new one. It could have broken off and that could be the red that you are seeing inside the speedo.
I don't have any suggestions for getting it out if that's what it is.
Old Mar 26, 2014 | 10:49 AM
AWilson's Avatar
AWilson
So you do know for sure that the new one is correct?
Old Mar 26, 2014 | 11:17 AM
Mike Ward's Avatar
Mike Ward
The cable on the left looks like the correct replacement part. The one on the right is a generic cars parts store cut-to-fit.
Try heating a pin red hot and pushing into the red piece inside the speedo. Let it cool and gently pull it out.
Old Mar 26, 2014 | 12:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe you're going to have to bite the bullet and remove the speedo from the dash. You really can't get to the rear of it with it in the dash and you are not likely to see what's up with the red plastic with it in the dash.
Correct drive for 68 is a screw on square cable per the one on the left in your pic.
Old Mar 26, 2014 | 06:42 PM
AWilson's Avatar
AWilson
Thanks guys for the help. I am off and running again! Love the hot pin idea. It might just work. But I am wondering if i can PUSH the broken piece out from the meter side.
Old Mar 26, 2014 | 06:59 PM
Mike Ward's Avatar
Mike Ward
No, that will destroy the instrument. Do not push.
Old Mar 26, 2014 | 07:05 PM
AWilson's Avatar
AWilson
MIKE YOU MADE MY DAY!!! IT WORKED!! THANK YOU SO MUCH!!
Old Mar 26, 2014 | 07:16 PM
Mike Ward's Avatar
Mike Ward
Cool! Glad it worked.
Old Mar 26, 2014 | 09:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This is exactly how I remove them... lol.. I'm impressed..
I usually take a piece of bowden cable and make a few notches in it with some wire cutters... gives the cable teeth.. heat to a glow and insert till cool.. works every time.
But.. the next question... usually when a cable is broken at the speedo/tach head, there is an issue with the head.. so don't be surprised if this happens again.
Willcox
Old Mar 27, 2014 | 09:36 AM
AWilson's Avatar
AWilson
Willcox
I used a piece of SS wire and put some minor bends in it so it stays in. Then I used a plumbing torch to like you said make it glow red while inserting. It was so easy I cant believe it!
I don't want to put this dash together only to learn that I need to take it apart again. I installed the cables on both the speedometer and tach and attached a hand drill running in reverse. They both seem to run fine, not noisy, no needle jump. The faceplates do not need refurbishing. So what are my chances I am ok? If I wanted to send them both in to you what would it cost for a simple functional inspection and lubrication? PM me if you prefer.
Old Mar 27, 2014 | 10:29 AM
Mike Ward's Avatar
Mike Ward
It's possible that the aftermarket cable end caused it's own problems. They're not a very good design. If it turns out that the instrument is faulty, then Ernie will fix you right up.
He comes highly recommended.
To 68 Speedometer cable confusion
