lower ball joints, 1978 corvette
Old Mar 29, 2014 | 04:55 AM
genep's Avatar
genep
Default lower ball joints, 1978 corvette
I just got my lower control arms back from the powder coater and found the new lower ball joints do not line up to mount the bolts that go through the side, they are aftermarket ball joints, has anyone else had this problem or did I just buy cheep ball joints.
Thanks for the help
What I mean is the side winges do not line up , they are about 3/16 " off of center forward , so the arms that bolt to the side extend to far into the frame.
Thanks for all the response
Old Mar 29, 2014 | 08:37 AM
Roadster71's Avatar
Roadster71
Thanks for the help
Seems to be a common problem. I'm in the process of doing the same thing. I replaced the joints only 4 years ago and am doing it again already.
The old joints had the same issue requiring some grinding of the ears to fit. After talking to my alignment guy I purchased joints from NAPA ( best ones ) which drop right in and usa made. Side by side with the old ones the machining quality looks much better.
Old Mar 29, 2014 | 10:29 AM
my 76 ray's Avatar
my 76 ray
That's interesting about the NAPA joints fitting. I've heard several times that the control arms tend to be deformed from setting the rivets. I know some people have "straightened" the control arms to make the ball joints fit. Some have "enlarged" the holes.
Old Mar 29, 2014 | 11:05 AM
Roadster71's Avatar
Roadster71
Its my understanding that if the original rivets are still there that the holes have to be enlarged to accept the bolts per the factory service manual.
Old Mar 29, 2014 | 08:07 PM
Arkyvette's Avatar
Arkyvette
I had to "massage" mine larger with a die grinder. Seems to be a common thing.
Old Mar 29, 2014 | 09:13 PM
MakoJoe's Avatar
MakoJoe
The ball joints should be able to drill out or grind off the rivets then use the bolts to mount them back in. I would not use local auto parts stores and buy them online. I bought a front end kit for my 1977 and the alignment shop was able to cut out the old ones and use the parts I supplied to them to install both the upper and lower ball joints without any cutting or hassle at all.
http://www.ecklerscorvette.com/corve...1963-1982.html
Old Mar 29, 2014 | 10:12 PM
Arkyvette's Avatar
Arkyvette
As mentioned above, sometimes the arms are bent during riveting, or during the drilling process, or maybe just from years of usage. I am sure that some just fall into place. Mine did not and they were Federal Moguls from an online parts kit. Next time I do mine, I will use MOOG ball joints from the parts store though. Only took 45 seconds or less to enlarge the holes and everything bolted in just fine after that.
Old Mar 30, 2014 | 05:25 AM
genep's Avatar
genep
Thanks to all ,
Old Mar 30, 2014 | 05:28 AM
genep's Avatar
genep
New problem, Trying to replace the transmission lines , up by the radiator thought someone cut the lines and put in rubber hoses, but it seems that they are supposed to be there, anyone know where I can get the replacement hoses.
Old Mar 30, 2014 | 09:58 AM
Arkyvette's Avatar
Arkyvette
Buy it by the foot from the parts store. They have big rolls to cut it from. Use new clamps and make sure they are on correctly. This isn't an easy place to work and I can tell you firsthand how much fluid and how fast it will come out of one of those hoses if they pop off.
Old Mar 30, 2014 | 10:12 AM
my 76 ray's Avatar
my 76 ray
I would spend the few bucks it costs to get the proper fittings. They have a bulge near the end. You push the rubber hose past the bulge and put the hose clamp on the line past the bulge so that the hose won't be blown off by the pressure.
Old Mar 30, 2014 | 10:24 AM
Arkyvette's Avatar
Arkyvette
Shouldn't his factory hard lines already have the bulge? Seems he just wants to replace the rubber sections. Mine already had it but different years for sure.
Old Mar 30, 2014 | 10:32 AM
my 76 ray's Avatar
my 76 ray
You are correct. But in the meantime I found a video on another thread that shows how you can make that bulge with a flaring tool.
Old Mar 30, 2014 | 12:17 PM
genep's Avatar
genep
Default tranny lines
Old Apr 1, 2014 | 07:39 AM
genep's Avatar
genep
Yes , the new lines have a flair on each end, I have 2 long lines and 2 short lines , that is what made me think the rubber or hydraulic hose is supposed to be there, thanks for the help
To lower ball joints, 1978 corvette
