Thinking about replacing my frame
Old Apr 4, 2014 | 11:28 AM
BBCorv70's Avatar
BBCorv70
$7K for a new frame?
Looks like $4500 from this vendor...
http://www.parts123.com/parts123/yb....Z5Z5Z50000082A
Are there any problems with this frame? Price incorrect?
Old Apr 4, 2014 | 01:59 PM
keithinspace's Avatar
keithinspace
Interesting. Not too specific on if it's NOS, newly built, or refurbished. No matter what, that isn't a bad price at all.
I'm working a trade+cash angle on the frame I'm eying now. May be able to get into it for $1k cash plus some parts I'm not using anyway. Will meander down this path first.
I appreciate the heads up, though. If I have to swing back to a different strategy, perhaps I'll give these folks a call...
Old Apr 4, 2014 | 02:41 PM
BBCorv70's Avatar
BBCorv70
I think I heard this vendor has the original tooling from A.O.Smith, the vendor who made the frames for GM. They're not NOS. Actually new frames from what I recall. I don't know much more about them.
Old Apr 4, 2014 | 08:39 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Most of the differences in frames come from differences in gas tanks, suspension, and front and rear bumpers. This is what I am pulling from memory... not 100% accurate.
For example:
1968 frames unique due to first year run.
1969-1972 Frames are inerchangeable.
1973-1974 Frames are interchangable because the add on of the early rubber bumpers with no impact crap behind them. (can be modified to work on earlier cars if you are good at welding)
1975-1977 Frames are interchangable because all the front/rear bumpers are the same and the gas tank remained the same
1978-1979 Are interchangeable due to a different gas tank (changed to a different size because of the bigger back window.)
1980-1982 are interchangeable because the front and rear bumpers are the same, gas tank is the same, and rear suspension is the same.
All automatic transmissions corvettes had frames with a removeable cross member, all standard transmission corvettes has the cross member welded in place.
Old Apr 4, 2014 | 08:48 PM
SB64's Avatar
SB64
Default frame
4spd frame has a welded crossmember, auto is bolted on. Gussets can be replaced. I had to do mine on my 69 rusted frame, along with some creative welding to the upkick rails.
R
Old Apr 4, 2014 | 09:42 PM
nelson007's Avatar
nelson007
I bought a factory replacement 1970 that was new last year at Carlisle for restoration of my 1970 lt1 convertable. I paid $2800.00 for it.
Nelson007
Old Apr 4, 2014 | 10:17 PM
dtamustang's Avatar
dtamustang
can anyone be more specific on what needs to be modified on 73-74 frames to work on earlier years ?
Old Apr 4, 2014 | 10:41 PM
keithinspace
Holy crap...THAT sounds like the ticket!
If this works out, it would still make sense money-wise.
If this DOESN'T work out, that may be a direction to head...go to Carlisle with a wad of cash and an empty trailer...
Old Apr 4, 2014 | 10:43 PM
keithinspace
Curious:
A bolt-in crossmember is desirable. So it may seem that I WANT an auto frame? Does the 4-speed otherwise just bolt in to an auto frame?
To that end, does the auto frame still have the Z-Bar mount? Or is that deleted from the auto frame?
If I get a manual frame, I'm going to modify it to make the cross-member removeable. Too much of a pain to pull the engine to access my transmission.
Old Apr 4, 2014 | 10:46 PM
keithinspace
From what I've read so far on this issue, mid-'68 frames up to the end of '74 are identical.
The "mod" that makes pre-mid-'68 a threshold is the large vertical gussets at the kickup.
The "mod" that makes the post-'74 threshold is the 'bumper tubes' that hold the 5 MPH bumper springs/hydraulics. The mid-'68 to '74 frames have all square metal in the back.
That's my understanding.
Old Apr 4, 2014 | 10:51 PM
nelson007's Avatar
nelson007
By the way i had about 4 to choose from. I am going to have my car judged, thats way I paid more for new frame. I bad to purchase a cross member because the factory replacement has the cross member that is bolted to the frame. How bad is your frame?
Nelson007
Old Apr 4, 2014 | 11:04 PM
nelson007's Avatar
nelson007
What year LT1 carb do you have?
Thanks,
Nelson007
I really appreciate the input and thoughts. I'm really hoping this local frame works out.
I have my old LT-1 Camel Hump heads, a good set of sidepipe headers, a complete LT-1 TI system, and an original LT-1 carb with correct metering blocks that I'm hoping to put in the mix as a partial trade/barter.
The guy who owns the frame rebuilds stuff, specifically Corvettes, and my engine builder (now frame broker) believes he'll work with me.
So, for the moment, hold that thought and let me chase down this lead for a week. If it falls flat on its face, I'll PM you. Those are all excellent thoughts.
So everyone knows, this isn't my first foray into frames...just the first hard lead I've had on a solid frame at a decent price. I asked a few non-local folks a few weeks ago and all the "bare frame" prices (no rehab, no sandblasting, nothing) were $3,500 to $4,500. It was discouraging, to say the least.
I don't disagree with the Steeroids thought. I can find a lot of uses for the gaping chasm between a $160 rebuilt box and a $1,300 Steeroids system. I know its better, but I can always add it later. Probably a good call.
Same with the trans. 60% chance I will drop my entire engine/clutch/trans setup onto the new frame without even cracking it open. I have <250 miles on the engine/clutch as I write this. 30% chance I'll open the trans and rebuild it. 10% chance I'll get a different trans.
I have a really good local powdercoater who can handle frames, so I'll probably get them to price it out. They do exceptional work and if it is under $500 for them to blast it and coat it, that'd be a no-brainer.
Old Apr 4, 2014 | 11:34 PM
  #33
68/70Vette's Avatar
68/70Vette
For now, just sitting here, I forget some of the frame specifics. The frame horn extensions...the body pieces that connect the frame to the bumper are different as you progress from a 68 frame to a 69 frame. Also, I bought a replacement frame for my 69 from GM. I bought the frame in 1980 and assumed it was a duplicate 1969 frame, it was only later that I found out that a replacement frame bought in the early 1980's would be a 1973 frame. So I have a 1973 frame, not a 1969 frame. Unfortunately, the frame extensions for the 1973 frame (once again purchased thinking it was a 69 frame) ail not exactly match up to my 1970 bumpers. ARggggh! A little torch and/or drilling will be required.
Old Apr 4, 2014 | 11:38 PM
  #34
dtamustang's Avatar
dtamustang
thanks for the clarification.
Old Apr 5, 2014 | 08:08 AM
  #35
keithinspace
Could be worse, I guess, but as I said in my OP, there is a vast combination of small and large things that make me want to take this project on.
The carb I am staring at right now is a "DZ" Holley 780 LIST-4053. My understanding is that it is original to a '69 Z-28. The carb itself, though, is 100% identical to the LT-1 Corvette carb. The dual metering blocks are correctly coded (4159/5583). It is in great shape, but needs to be rebuilt by someone who knows what they're doing.
Old Apr 5, 2014 | 08:31 AM
  #36
davidchristopher's Avatar
davidchristopher
I may have answered my own question with some additional research...
I think I'm looking for a car that DOES have the "kickup" gussets near the doglegs that were added in mid-1968 but DOES NOT have the "hydraulic bumper shock" tubes that were added in 1975?
If I'm creeping in on the right answer there, I'm still trying to find the big difference between an auto and 4-speed frame...
Yeah- the years you're looking for would be 69-74. Note: 68s had some differences, and the bumpers changed in the rear in 74- I'm not sure if the 74s will work for you. Looking at the pics they should be okay.
'm doing the opposite swap - my '69 frame for 800 is going under a 73.
In a month or so I'll probably have the two frames side by side as I transfer components over, I'll know for sure then
Old Apr 7, 2014 | 09:45 PM
  #37
keithinspace
I learned that the frame in question is not a "complete" frame, but is the rear half of a '69 and the front half of something else. A '75, I think.
He was going to put in the removable crossmember as well as the z-bar mount, making it a custom frame specifically for me.
The guy has done this many times and is very comfortable in his work. I'm not UNCOMFORTABLE in it since the frame would CERTAINLY be straighter than the one under my car now. But this development has made me take a step back.
The offer on the table is $1,800 with me trading away a few of my 'stored' parts such as my old LT-1 heads and an original 1969 "DZ" code carb I have. I think I could get some off for my original drop-base air cleaner assembly with original wing nut. There may be a little more wiggle room in there.
This has prompted me to want to take a step back and see if there are any other options out there.
If this is a VERY VERY nice frame other than the fact that it is two frames welded together, I may be OK with it. It doesn't bother me, really, but I just have to feel comfortable that it was done right.
I need to compare that thought to paying $1k to $3k more for a "one piece" frame that isn't the best of two frames, but one frame that is in OK shape.
Decisions.
Any input?
To Thinking about replacing my frame
Old Apr 7, 2014 | 11:07 PM
  #38
dtamustang's Avatar
dtamustang
just a few random thoughts...first from what I can come up with a 4 speed frame has the trans crossmember welded to the frame , the auto version is a bolt in crossmember, with no provision for a z-bar.
second , I have been looking around and 68-72 frames seem to be a bit more spendy than the later frames. there must be some differences in the post 72 frames that would cause the price drop that I don't know about.
third, and this is strictly my opinion , a welded frame repaired or two welded together to make a good one would not be a problem with me. however I would take a lot of time and effort checking it out for dimensional correctness. it could be one of those things that will make your life miserable if there are some boo boos that found their way in to the finished product.
Old Aug 31, 2015 | 11:56 AM
  #39
rczwerver's Avatar
rczwerver
1st Gear
Default Frames
Can someone tell me if I can use a 1976 frame under my 1973.
Or what is the different between the two frames.
Old Aug 31, 2015 | 10:17 PM
  #40
Jesse 982's Avatar
Jesse 982
I am in the process of stripping down the chassis of my 68 vert due to a broken drivers side kick up. It's rusted out and I dont want to put a band aid on it so I looked into the frames at Vette Products of MI. I live about 25 miles away so I drove over and walked through his shop.
He bought all the tooling from GM and makes factory spec C3 frames and many other chassis parts. He has some nice frames stacked up and will make any adjustments you request. I plan on ordering a manual frame with removable cross member and adding the dog leg supports that the late 68's came with. More than I want to spend but I dont want any problems going back together and only want to due this once.
Jesse 982
