Installed some DRL's
Old Apr 4, 2014 | 10:50 AM
speedreed8's Avatar
speedreed8
Default Installed some DRL's
added some daytime running lights for a little safety. was also a chance to clean and repaint the lower grills.
Old Apr 4, 2014 | 10:55 AM
MrJlr's Avatar
MrJlr
Looks great
Old Apr 4, 2014 | 11:04 AM
briankeery's Avatar
briankeery
That makes a lot of sense these days, as does a working horn.
Old Apr 4, 2014 | 11:32 AM
Chadillac2000's Avatar
Chadillac2000
I really like those for the aesthetics alone. I wonder what a set of HID foglight projectors would look like down there used as drls? For how cheap you can get a reliable set of those these days, I may look into it. Something similar to this:
Old Apr 4, 2014 | 11:49 AM
Trae1976's Avatar
Trae1976
I like it!
Old Apr 4, 2014 | 12:33 PM
Paul L's Avatar
Paul L
Very nice job! Mine should be installed in mid-April.
Old Apr 4, 2014 | 01:13 PM
speedreed8's Avatar
speedreed8
They are called driving lights on the pkg. they were only $18....
Old Apr 4, 2014 | 01:28 PM
GreenDream's Avatar
GreenDream
Great idea. I have been thinking about this myself. Where did you wire them into? did you use a relay?
Old Apr 4, 2014 | 01:39 PM
speedreed8's Avatar
speedreed8
i used a relay, the lights get power directly off the alternator (cs140), i do have a circuit breaker between the alt. & relay, the relay coil is powered off the fuse box from one of the IGN. plugs (which is protected by the gauges fuse 10 a). i put a switch inside also if i want to turn them off. the lights draw 15 amps. ( so says the pkg they were in)
my headlights use relays also...
To Installed some DRL's
