68 Dash Pad install
Old Apr 7, 2014 | 02:14 PM
carlisle61's Avatar
carlisle61
Default 68 Dash Pad install
I'm in the process of putting the top dash pad back into car and I need some help. The windshield is out of the car. All of the lower parts of the dash are installed. The problem I'm having is the top pad is not able to go in between the windshield pillars. I might be able to force it, but am reluctant. Any suggestions?
Old Apr 7, 2014 | 02:39 PM
C3 Stroker's Avatar
C3 Stroker
It's easier when you install the upper dash pad first (it's like a jigsaw puzzle, correct order makes it easier). The new pieces are usually a tight (exact) fit. I used a heat gun to soften the new pieces for easier handling on my '69.
Old Apr 7, 2014 | 09:20 PM
CF6873's Avatar
CF6873
You will have to bow it up in the middle to force it between the pillars.
I heated mine in the middle with a heat gun to make it less brittle and then squeeze it in.
Good Luck
Old Apr 7, 2014 | 09:33 PM
redrdstr72's Avatar
redrdstr72
Good Luck
In addition to this, I think you need to remove the A pillar and header trim. The header trim trim doesn't really need to be out to get the upper dash pad in, however, it has to come out to get the pillar trim out.
Old Apr 8, 2014 | 03:24 AM
7T1vette's Avatar
7T1vette
Top pad installs BEFORE the lower dash pads.
To 68 Dash Pad install
