Oil leak
It sometimes takes a bit of work to find a fluid leak when you are looking at the car, let alone trying to do it over the internet never seeing the car. If its a fluid my car has leaked it.
If you run your P/S pump total out of fluid it will most likely over heat it and burn it up. However if it leaked all of its fluid within a day I would think that would be somewhat of a alarming amount of fluid on the floor.
My car may an hour and a half. The size of the wet spots was about the size of a donut tire. Then after it was parked in my garage a few hours, I went to check and the spot was about the size of a dinner plate maybe a bit smaller.
Antifreeze from the radiator can also have a oily texture to it.
You could taste it.
Bitter sweet is antifreeze. Anything else tastes real awful.
Not the best way, but i've had every fluid from a vette in my mouth one time or another working on it. None of them would be good on a burger.
- kinda like that, well the coolant starts at the seventh rib.
Also I checked the power steering fluid and it's so low that it barely ready on the dip stick.
Antifreeze/water mix on the other hand will evaporate. So the bad news is it your radiator. But also good because it has the greatest capacity of anything else that leaks.
Top off the radiator with water, start it up and it will get up to temp just idling.
That should provide enough pressure to get it to leak again for confirmation.
Then before you shut it down fill your overflow reservoir if it has one. It is located on the passenger side under the hood kind of tucked under the fender well.
Topping that off will allow it to suck water into the radiator as it cools after you shut it off.
Then next time, after it's cooled, before you drive it to the mechanic, check to see that the radiator is then full. If it's not top it off before driving it 40 minutes. Keep an eye on the temp gauge on the way to the mechanic to insure that your leak didn't suddenly get worse and dump all your water out causing the engine to overheat.
Once you get it fixed then make sure the antifreeze/water mix is replaced to the proper level. Your mechanic should insure this for you.
If your really concerned about the leak suddenly worsening while driving it to the mechanic get it towed there.
If you have a Pep boys, Autozone or other franchise auto store that is close...like minutes, you could drive it there and have one of the guys check it out. They usually have basic tools and could do a quick fix.
I used to credit myself for having common since but lately I am beginning to wonder. The way you eliminated fluids because oil doesn't dry up. You are so right!!! I knew that, why didn't I think of it. As soon as I read it, it was like a bell went off in my head. All I could think was, DUH!!! Once again simply genius. I guess common since is not as common as it once was.
Again I must thank you and everyone here on the forum for sharing with me your knowledge (and common since,) giving your time, and putting up with me in general.
Now what about my battery light coming on? If I just go buy and new battery, would that be a quick fix?
The reason I ask is that the A/C evaporator is cold and water vapor from the air condenses on it when your running the A/C or the defroster, and then it drips that water out under the car near the front tire area.
Drip is green liquid and not clear? Tastes bitter sweet?
If yes, then it is your radiator, or I should say it is radiator fluid. It could be a loose connection or a hose with a leak, or the water pump, but at least you know from which system it is coming.
Your battery light is indicating that the alternator is not charging correctly.
Does it come on strong at idle and not go off or does it sort of glow/flicker and either go off or dim when you rev it up a little?
Usually it is just the brushes on the alternator are worn out.
with the engine off, check that your alternator connections are plugged in firmly.
Alternator is on drivers side, belt driven, has wires coming out the back.
While your there check to see that the belt is reasonably tight as well.
The leak is in the front on the passenger side, directly under the radiator. The taste is bitter sweet, the color had a slight yellow tint. There was no green color. My A/C is off and the defrost also. It's not the drip I always see from my A/C
I checked my radiator coolant this morning and it's full the overflow is at the cold mark. My transmission oil is full. I checked the belt on the alternator and it tight and all the connections are all plugged in nice an tight.
The battery light is dim, stays on, and stays dim, even when I rev it up. The gauge on the dash reads 8, on the drivers side, then 13, in the middle, then 18, towards the passenger side. It is pointing almost in the red on the passenger side, the 18. Would that mean that the alternator is over charging my battery?
I am going to take to out this morning. Going about 15 miles then gonna stop there for an hour or so and drive back. I'll let you know how it does.
