Okay gents im having a little problem i bought 17x8 ridler wheels and i went with 235/50/17 their is way to much spacing between the tire and fender. not sure what to do because i want it to look good and handle good too. any help would be great.
The stock tires most C3's were delivered with had a 27+ inch height. Your 235/50's are approx. 26 inch height. If you want to duplicate the wheelwell filling look of stock, you need 255/50's, which have a height of 27.1 inches
I already bought the tires and put them on the rims. So that is out of the question. I will deal with try h What I bought. All I wanted to know is What route I should use to lower the car.
I have 26'' tires on my car as well although they are 255/45ZR17, so a little wider than yours. I also have the correct backspace, you haven't said what your backspace is yet.
with a 26'' tire you absolutely have to lower the car or it will look funny. I used 8'' bolts in the rear and cut one tight coil off the stock front springs.
