Reverse Flow Glasspacks
Old Apr 11, 2014 | 02:16 AM
illenema's Avatar
illenema
Default Reverse Flow Glasspacks
Hey there are 2 versions of these, small block and big block Anybody know the inside diameter of each???
Old Apr 11, 2014 | 07:03 AM
Super6's Avatar
Super6
I don't know the answer to your question.
Is that your blower-equipped Vette in the avatar? If that's your engine, going with the most restrictive muffler insert made doesn't seem like a good match for producing horsepower.
Old Apr 11, 2014 | 07:47 AM
MIKE80's Avatar
MIKE80
I have a small block with Hookers Max Flow inserts. Hooker says they flow better than open headers. Inside diameter is 2.5". And yes, they are loud.
Old Apr 11, 2014 | 02:40 PM
Super6's Avatar
Super6
Mike,
I think the OP was asking about reverse-full inserts.
OP, if you don't know there are 3 grades of Hooker inserts. From quietest to loudest...reverse-flow, glass-paks and max-flows. The glass-paks have a 1 7/8" pipe ID. I also have Max-Flows and they are loud for sure.
Old Apr 11, 2014 | 08:17 PM
illenema's Avatar
illenema
There are actually a different current reverse flow parts numbers on For SB and One for BB. Anyone know what the inner diameter of each is?
Just curious.
I do not plan on using either when replace current system. Its between Sweet thunder and STS spirals I have listened to every sound clip and found all power charts on both.
Avatar car is alive and well. And loved.
Here is mine Small block yes?
To Reverse Flow Glasspacks
