headlights shut off for no reason?
Old Apr 13, 2014 | 05:46 PM
alconk's Avatar
alconk
Default headlights shut off for no reason?
Well the other night I was on a country road about midnight and had the highbeams on, no other person around and out of nowhere the headlights shut off. I pushed the h/l switch to off the turned em back on. They worked the rest of the way home but didn't use the high beams. So couple of things, it did this last fall in the exact same area about the same time which is creepy or the headlight switch is overheating causing the circut breaker to trip shutting off the lights. High beams are stock replacement and the lows are Hellas with the stock wattage bulb. What could be causing this?
Old Apr 13, 2014 | 08:06 PM
Street Rat's Avatar
Street Rat
I had this happen to me one day prior to sunrise. That was fortunate. I had upgraded all of my headlights with new halogens prior to that. The headlight switch has some type of circuit that keeps it from overloading. So what I did was install relays to turn on the lights. This allowed the switch not to handle all of the voltage when the lights were on. No more problems. There are numerous threads on the headlight upgrade if you do a search.
Old Apr 13, 2014 | 08:34 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Or there might be an alien base in the area.
Old Apr 13, 2014 | 09:16 PM
C376FL's Avatar
C376FL
Hi alconk I had the same thing happen to me when I was coming home one night from a car show. I just chalked it up to a short that I would check out later. When I turned the bright lights off it was fine. I'm glad to see that it might something simple, instead of tracking down a short.
Larry
Old Apr 13, 2014 | 11:22 PM
alconk's Avatar
alconk
That's what I was thinking.
Old Apr 13, 2014 | 11:25 PM
alconk's Avatar
alconk
You know awhile back I was thinking about doing the relays but was having a hard time determining where to tap for power. Now I guess I will look back into this.
Old Apr 13, 2014 | 11:57 PM
addballer696's Avatar
addballer696
same exact problem with me. Bought everything to do the relay mod just haven't gotten around to it. Let me know how it works out!
To headlights shut off for no reason?
