trailing arm bolt removal
Old Apr 23, 2014 | 08:16 PM
acco 50's Avatar
acco 50
Default trailing arm bolt removal
Hello, in the process of removing my trailing arms for the restoration, broke one nut off and removed the other but the bolts will not back out, they will turn but will not come out even with hammer and punch, I heated some and soaked down with WD-40, What did you have to do to get them out? Thanks, (RIGHT SIDE)
Old Apr 23, 2014 | 08:25 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I soaked them every day for a week/worked the arms up/down....I still needed a 5 lb. mall and a couple different size punches to drive them out even after I got them to turn. Just make sure the car is on stable jack-stands/or a lift.
(Order some new hardware from one of the Forum Vendors once you make a list of parts to-buy)
Old Apr 23, 2014 | 08:33 PM
acco 50's Avatar
acco 50
Thank you, acco (LEFT SIDE)
Old Apr 23, 2014 | 08:39 PM
doorgunner's Avatar
doorgunner
Originally Posted by acco 50
Thank you, acco
FYI...........wear gloves.....take your time....your fingers will thank you.
Old Apr 23, 2014 | 08:40 PM
Sacred Steel's Avatar
Sacred Steel
They are probably rusted to the bushing sleeve. Thats why they turn but wont come out. That happened to me and I had to use a sawsall.
Old Apr 23, 2014 | 08:48 PM
acco 50's Avatar
acco 50
Noted
acco 50's Avatar
acco 50
Thanks, acco
Old Apr 23, 2014 | 10:31 PM
edk136's Avatar
edk136
I used an air hammer with a chisel point. After a good soaking with a 50/50 mix of Acetone/Automatic Trans Fluid... the bolts came right out.
Old Apr 24, 2014 | 12:23 PM
acco 50's Avatar
acco 50
Thanks, acco
Old Apr 24, 2014 | 04:15 PM
Dodosmike's Avatar
Dodosmike
Drop the wheels and use a sawzall and cut the bolts off where the shims go. Between the T/A and the frame
Dodosmike
Old Apr 24, 2014 | 07:59 PM
wilesre's Avatar
wilesre
Buy a MAPP torch and get that sleeve red hot. No body, right? It'll pop right out.
Old Apr 26, 2014 | 12:18 AM
Korevette's Avatar
Korevette
I agree with Dodosmike, get a quality saw with a variable speed and start out slow. Lot's of safety.
There is a lot of info in the Search window on the process. As a bit of advice, buy the very best saw blades you can, your muscles will thank you for it.
Old Apr 26, 2014 | 01:15 AM
RBrid's Avatar
RBrid
Default Good Good Good Vibrations
If you go the sawzall way, get ready for some good good good vibrations
Here's what it took for both of my trailing arms:
Old Apr 26, 2014 | 06:58 AM
LS4 PILOT's Avatar
LS4 PILOT
Sawing the bolt can be done with car on stands. Bad experience .
But let me say this job , it is actually pretty easy if you put the car on a lift , so you can stand up and bring pressure to bare at the right points. Took maybe 15 or 20 minutes to make four cuts and arms fell out .
Car on the ground , laying on your side or back is very frustrating .
My friend also bought some special long blades from Lowes that required only two blades to make the four cuts. They were expensive .
Old Apr 26, 2014 | 07:41 AM
Hezzy's Avatar
Hezzy
ouch!!
Old Apr 26, 2014 | 10:14 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Been there, done that. BTW, both struts had been bent from a trip to Bubba's alignment shop so they were sacrificed during removal.
Purchased and installed SS pivot bolt to avoid this exercise in the future.
Good luck.
Old Apr 26, 2014 | 10:39 AM
LS4 PILOT's Avatar
LS4 PILOT
Use stainless shim kit
Btw ...it's worth the $ and trouble. C3 is a good handling car if all the suspension is up to spec.
Replaced the front springs on my car few years ago , it made a world of difference in handling and ride.
To trailing arm bolt removal
Old Apr 27, 2014 | 02:16 PM
acco 50's Avatar
acco 50
Thanks, acco
Old Apr 27, 2014 | 02:40 PM
acco 50's Avatar
acco 50
Default Trailing arm removal success
Got the arms removed, IMG_0405.jpg (71.2 KB)
IMG_0421.jpg (75.4 KB) Left trailing arm, Left pocket IMG_0407.jpg (79.2 KB)
IMG_0416.jpg (78.5 KB) Right trailing arm Right pocket I gave up on the sawzall and the air hammer and burned them out, my air hammer quit on me, need a new one
Old Apr 27, 2014 | 11:45 PM
doorgunner's Avatar
doorgunner
F I R E.....GR-R-R-R....FIRE B A D!!!!!
But fire......good.......on rusty bolts!
