Rear leaf spring bolt question?
Old Apr 23, 2014 | 09:16 PM
alconk's Avatar
alconk
Default Rear leaf spring bolt question?
A couple of years ago I had to replave my damaged fiberglass spring with a new one, well I used new original style bolts that had the hole going through for a cotter pin. Well I thought the back sat up to high so just recently I bought the longer bolts with poly bushings and now I have it sitting mostly level but the longer bolts does not have the hole provision for a cotter pin. Is that ok? It came with lock nuts and have been driving the car that way now with no problems but just wondering if that's fine. I only have a couple of threads sticking out of the locknut.
Old Apr 23, 2014 | 09:21 PM
'75's Avatar
'75
The lock nut should work fine.
Old Apr 24, 2014 | 12:38 AM
alconk's Avatar
alconk
Ok thanks.
Old Apr 24, 2014 | 03:27 AM
mac79vette's Avatar
mac79vette
I have seen a vette where the lock nut came off so on mine I have the lock nut and then added a 2nd nut to lock it down.
Old Apr 24, 2014 | 05:09 AM
pacecar620's Avatar
pacecar620
If you can afford 50 whole cents for the peace of mind, add the jam nuts to the bolts and rock on.
Old Apr 24, 2014 | 10:57 AM
alconk's Avatar
alconk
I don't have the room to add anything, like I said I only have a thread or two showing.
Old Apr 24, 2014 | 06:16 PM
briankeery's Avatar
briankeery
Weekly circle check.....just add that to your list,
Old Apr 24, 2014 | 08:03 PM
wilesre's Avatar
wilesre
Use a big set of pliers or a couple of hammers and mash the threads that are exposed.
Old Apr 24, 2014 | 08:26 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Yes, staking the threads would have the same effect but new hardware will be necessary in the future. Not expensive....
To Rear leaf spring bolt question?
