Earliest C3 cruise control?
Old Apr 30, 2014 | 01:09 AM
ChrisMiami's Avatar
ChrisMiami
Default Earliest C3 cruise control?
I'm seeing various vendors offering "1969 Cruise Control Module", but I don't see that anywhere in the AIM and my recollection is that CC wasn't available till after 1976.
Does anyone know when cruise control was first available?
If there was a factory option for this in 69, can you give me an AIM page? (And if you can I want my money back on the index!)
It doesn't show up here either http://www.69corvette.com/69specs.html or here http://www.gmheritagecenter.com/gm-h...tion-kits.html
Thanks,
Chris
Old Apr 30, 2014 | 06:24 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
77 was the first year cruise was offered from the factory.
Old Apr 30, 2014 | 06:34 AM
MrJlr's Avatar
MrJlr
I had one.....it almost killed me.
Under WOT, the plastic clip pulled through the metal bracket and stuck not cool.
Old Apr 30, 2014 | 08:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ChrisMiami
...I'm seeing various vendors offering "1969 Cruise Control Modules...
You don't want one.
Old Apr 30, 2014 | 11:19 AM
ChrisMiami's Avatar
ChrisMiami
Today I saw the last page of the Chassis svc man describes something under Specifications/Accessories called cruise master. That's the only actual reference I've yet seen.
Old Apr 30, 2014 | 05:24 PM
7T1vette's Avatar
7T1vette
GM put cruise controls on lots of models, starting in the early 70's. But, Corvette resisted offering cruise until 1976. The basic units are the same and can be swapped across model lines, easily.
But, I agree that a more modern, electronic unit is better. Rostra sells a nice unit. Or, if you can scrounge-up an AudioVox CCS-100 unit [AudioVox sold out to Rostra], it will work fine, too.
To Earliest C3 cruise control?
