wiper door moulding
Old May 3, 2014 | 12:43 PM
cajos's Avatar
cajos
Default wiper door moulding
Is there a trick to get the wiper door moulding back on to the wiper door without scratching paint or break a clip? (1972 build)
Old May 4, 2014 | 10:04 PM
CF6873's Avatar
CF6873
Ttt
Old May 5, 2014 | 11:15 AM
Alan 71's Avatar
Alan 71
Hi c,
There's a couple of things you can do.
Make sure the clips are on correctly. They have an up-side and down-side.
The clips can be tapped into place from the back side if the trim piece is held securely in place.
Or you can put the clips in place first and lay a piece of tape across the door just at the 'rise' to protect the paint as you push the trim onto the clips.
Good Luck!
regards,
Alan
They go on this way.
To wiper door moulding
