Is this a fuel pump problem?
Old May 7, 2014 | 07:07 PM
Delta26's Avatar
Delta26
Default Is this a fuel pump problem?
Yesterday I went to home depot and bam, all of a sudden with the clutch in and foot off the gas, the rpms drop and the car cuts off. It started again after turning over several times. Did it again coming home at the stop light.
I had a remanufactured fuel pump put in last August.
Old May 7, 2014 | 07:15 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Fuel pumps usually quit once and completely. But anything is possible.
Old May 7, 2014 | 08:18 PM
Stingray Wes's Avatar
Stingray Wes
Sounds like the carb could be loading up on you and flooding out.
Old May 8, 2014 | 01:13 AM
Super6's Avatar
Super6
Water in the gas? Vapor lock from running hot or fuel line near headers?
Old May 8, 2014 | 07:50 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Could be any of the above or even the fuel filter. Could be a burned plug wire or two as well. Next time it dies, take the air filter off and see if you're getting a spurt of fuel when to hit the throttle. At least you can start narrowing it down.
Old May 9, 2014 | 04:52 PM
Delta26's Avatar
Delta26
I srarted it up yesterday and let it idle. Doesn't cut off even when I push the clutch in and put it in gear and let it idle.
I also have a pretty strong gas smell in the garage.
Old May 13, 2014 | 03:57 PM
Delta26's Avatar
Delta26
ttt
To Is this a fuel pump problem?
